Question about Dell Inspiron 1100 Notebook
Monitor on Dell 1100
I have trouble with the screen size after I installed VISTA on my Inspiron 1100. I cannot expand boeyong 16 bits.
  • Anonymous Apr 22, 2008
    Same problem here. Dell's web site seems to only list drivers for XP.
  • Anonymous Apr 28, 2008
    i have same problem.. but with xp.. the resolution is 600 x 480 at 16 bits.. does not goes further..
    any help
  • 3 Answers
What type of video card does your laptop have?? A lot of video cards are not compatible with Vista. Did you try to going to the manufacturer's website and checking for a updates on your video card? They might have a update for Vista? If you can find out what type of video card you have. Since this is a dell, you should be able to contact dell. Give them your laptop number and they can tell you what make and model you have installed.
Posted on Apr 03, 2008
SOURCE:
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Sep 17, 2011 | Dell Inspiron 1720 PC Notebook
My dell inspiron 1100 screen goes black
Fist ot alla, try to connect the notebook to an external monitor and check if you can show image when the issue appare.
Oct 19, 2009 | Dell Inspiron 1100 Notebook
Screen is all warped
Hi I am Vortash It sounds like your graphics driver has become corrupt restore may be an option however it may be better to reinstall the graphic card drivers .. uninstall the monitor first from your Device manager screen by selecting ..Control Panel .. and then device manager if in vista
and if in xp control panel...system .. device manager .. click on the display and uninstall ... click on display adapter and uninstall .. turn off and reboot place whatever disk in the cd the installation wiz ask's for and let the system do the rest. follow the same proceadure and install the next device then reboot and see if that has cured your problem if not there may be the chance your set has had a knock and the LCD has been damaged ... hope this helps Regards Vortash
May 05, 2009 | Dell Inspiron 1100 Notebook
Screen jumps...cant use computer it is so bad.
Update the driver for the monitor and adapter
If the system is fairly new it's usually a driver issue
May 01, 2009 | Dell Inspiron 530 Desktop Computer
Vista onto dell inspiron 1000
NO. You do not have a 64 bit processor. Also, Vista 64 is a memory hog and u need at least 1 GB.
Apr 25, 2009 | Dell Inspiron 1000 Notebook
I-INC monitor to use with my Dell Laptop, no signal to monitor?
When Windows logo disappear on the I-INC, do you still see it on the Laptop monitor?
All laptops have function keys to switch the screen between the external monitor (I-INC) and laptop monitor. On your laptop, it is Fn+F8 key. Press them once and wait for 3 seconds, it will switch the image between 2 monitors (external monitor ONLY, laptop monitor ONLY, and both).
During start-up, do not close the laptop cover. Because it may put your laptop into a stand-by mode and turn off the screen. You need to modify this Power Option setting within the Control Panel.
Mar 28, 2009 | Dell Inspiron 1100 Notebook
Computer not working no screen boot up or nothing
reconnect hard disk cable and re arrenge or re instal ram.
Mar 13, 2009 | Dell Inspiron 1100 Notebook
Switch monitors between a inspiron 1100 & lattitude d600??
Im not sure if the're compatible. The're the same display type ( TFT active matrix) but that would also depend on your video card. Your best bet is to buy an external 15" lcd monitor as you can find one for under $100.
Jan 11, 2009 | Dell Inspiron 1100 Notebook
I have dell inspiron 1100 need to know if it can split screen
I beleive if you go to the Dell support website it appears a lot of their laptops at least of this vintage did not support split desktop. I was looking to do the same and also very surprised to discover this! Best regards!
Jul 31, 2008 | HP (A4688-69911) (A468862911) Bridge
Inspriron 1100
laptops are very specific about what you can replace parts with.
Take it back to where you bought it and ask to exchange for a 14 "
If you want to see a bigger picture on that laptop the only way is to plug in an external monitor; in the back there should be a plug for an external monitor. Plug this in to any computer monitor. You will have to adjust the resolution.
May 13, 2008 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 Notebook Logo
98 people viewed this question
Ekse
Clive
Clive
