Technics su-v98. Powers on but no sound can be heard, not even through the headphones jack.
Can you tell me where all the jumpers go from the components on 2 amp?
Posted on Dec 20, 2008
The Technics SU-v98 will not produce sound if the jumpers are missing form the PRE OUT MAIN IN on the back of the unit. You can jump across left to left right to right, horizontally to fix this issue.
A Google search will take you to a free manual site for a Service Manual.
Panasonic still supports this with parts according to their website.
Hope this helps.
Jeff
Posted on Aug 31, 2008
    Scholar:
  • 105 Answers
Make sure it is not on mute. Check rear of receiver to make sure AUDIO IN has not become disconnected. Check input selector and verify that it matches the audio source.
Posted on Apr 03, 2008
My technics integrated receiver su-g75 is stuck in
The headphone jack is stuck, something got in there. Probably have to take it apart, but it might be a piece of a plug. Use flashlight...
Aug 28, 2014 | Audio Players & Recorders
Ok I have a technics integrated receiver su-g75 it
The amplifier power transistors could be bad, the speakers can be muted or a fuse for the speakers could have opened.
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me...
Try plugging in headphones to the headphone jack, then take the plug out. Some models of Denon receivers had faulty headphone jacks in them that caused the unit to think there were headphones plugged in even when there wasn't.
Mar 22, 2013 | Audio Players & Recorders
Looking for shorting pins for technics model su-v98-km1
You can make it by yourself. All you have to do is to shorten a pair of RCA cord to about 2 inches and then plug them into the
shorting pins hole.
Sep 17, 2010 | Technics SUV500 2-Channel Amplifier
Iam using ubuntu 9.04.sound card is not working.I
If you are getting sound through your speakers then the sound system is working. If you lose the sound when using the headphone jack then either the headphone jack is faulty or your headphones are...
Although, rarely, you may find that opening the alsamixer from the terminal will fix the problem as some versions of Ubuntu have a special volume control for the headphone jack....
You will need to open the mixer as the Administrator
Type
su aslamixer
If this helped please vote kindly
Oct 07, 2009 | Canonical Ltd. Ubuntu
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Technicks amplifier su-v98 no sound all other things work
The power amp section is bad or in protect mode.(shorted speaker wire)
Paul
Jun 10, 2009 | Technics SUV500 2-Channel Amplifier
Technics SU-V98 No Sound
If I understand your posting correctly, the amp works using the Aux In connectors but not using the VCR1 even when VCR1 is selected correct? If that is the case, there is an internal electronic switching IC (TA9263 I think) that may be defective. This is not a complex repair and can be confirmed easily by any shop that does audio repair. They will trace the incoming signal with an oscilloscope to the IC and see nothing come out when VCR1 is selected. The IC costs less than $10.
Dan
Feb 05, 2009 | Technics SUV500 2-Channel Amplifier
589 people viewed this question
 Grubhead
Grubhead
