Question about Kitchen Ranges
The front left burner on the stove does not ignite.
  • ajhufnagel Aug 04, 2008
    We have a whirlpool electric range. When you try to bake, broil, or use the burners they just dont heat up. Also when you press bake the degress sign next to the temp flashes.
What make and model is the stove? Is it getting gas? Can you light it with a match? Consider putting your face right over the burner and open the pilot to high. Let it run for 10 seconds and then light the pilot.
Posted on Apr 26, 2008
  • 109 Answers
You have one of three problems. first check to se if it's sparking when turning on, if not try cleaning sparker with a small wire brush, second try turning on another burner and see if it sparks then, if it does the switch is bad (under the knob), third is to replace spark module. ( on the back of unit small blu, white, box with four wires going up to cooktop)
Posted on Apr 03, 2008
SOURCE:
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
My Maytag kitchen range left front burner does not ignite/clic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 05, 2010 | Maytag MGS5770 Gas Kitchen Range
Left front burner not igniting...no spark but has gas,
automatic re ignition control (spark module), that's a common issue on all viking stove.
appliancesrepairla.com
May 12, 2010 | Viking VGIC485-6G Gas Kitchen Range
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
Stove help
I'd like to know, too. Thank you for your help.
Jul 27, 2008 | Tappan TGF320 Gas Kitchen Range
Stove top burner Spectra XL4
rear left back burner clicks to ignite but doesnt
Feb 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
173 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
