Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Resetting lamp replacement warning
I've replaced the lamp on my Panasonic PT-45LC12-K. Can you tell me how to turn off the "replace lamp" warning when the TV is turned on? I understand these directions are normally included with the replacement lamp. I purchased an aftermarket lamp which did not include these directions.
Thanks!
Haj
hsano@alum.mit.edu
  • Hajime Sano Apr 09, 2008
    Thanks! That did it.
    Not very intuitive, but I guess there's not much chance of accidentally hitting this key combination.
    Problem Solver:
Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
Posted on Apr 08, 2008
Lamp light out ?
Ck Fan behind Lamp first if it is OK then replace Lamp Look on E-Bay you can find lamps for as little as 82.00
Aug 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
How to reset lamp meter
I have a PT-50LCX63 unit. After 5 years and 4 bulbs, a "reset lamp" warning showed up every time I turned on the tv. I have to say that after a few weeks, the message ceased on its own. I don't know if all models eventually reset or turn off, but I could not find any other information on the direct way of resetting. I find the warning a waste of time since the bulbs are good for 10 -14 months. Sadly I missed the class action suit that dealt with the premature lamp failures. I am looking for a new tv at this point. Bulbs have cost me $1200.00 since I bought it. The warning is supposed to allow you the option of replacing the lamp before it fails, Ha! what a joke...Thanks for reading.
Dec 29, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Panasonic TV
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Jul 08, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT- 44 LCX 65 tv
I need to replace the lamp on this TV. What do I need to do
Jan 20, 2008 | Panasonic PT-45LC12 45" Rear Projection...
My PT-45LC12 has picture and fan problems
More like lamp failure. Could be other things of course but start with the lamp cause it will need it anyway if has been a couple years.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Jan 10, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
216 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
