Question about Garmin Rino 120 2-Way Radio
Garmin 120 will not turn on
My garmin 120 won't turn on. I checked and replaced the batteries to include moving the battery connections for better contact. But nothing happens. Checked the batteries to ensure they are good.
  • Anonymous Apr 04, 2008
    I have the same problem!
    One hour before it worked like a charme, then i shut it off and after one hour it didn't work anymore! It doesn't even turn on!!
    What should I do?
    Batteries are ok, i tried like 4 different sets, all working
  • donda May 19, 2008
    wake up this morning and nothing, no power, new batteries, can you soft reset this unit ?
I talked with garmin tech today, he said to hold the button below talk, and the wheel and the power at the same time to master reset....it did not work for me but it might for someone else
Posted on May 19, 2008
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
Garmin won't switch off
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults. ..reassemble
Feb 06, 2013 | Garmin Edge 705 Handheld GPS Receiver
My Garmin nuvi 295W won't turn on at all.?
Did you get the battery reinstalled correctly? The battery and a question mark means there's a battery problem.
Garmin Nuvi Gps
Aug 19, 2012 | Garmin Nuvi 295W 3.5 in. Car GPS Receiver
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
I have a cracked screen on my garmin nuvi 255w, can it be replaced?
Yes the touchscreen is repairable through a Garmin certified dealer, unfortunately the cost of repair would be close to 120$ where a new nuvi 255W goes for 99$. So you are better off upgrading or purchasing a new 255W. I would recommend investing in something with lifetime maps included, he unit will have an LMT behind them.
Hope this helps!
Apr 06, 2011 | Garmin GPS
I HAVE A GARMIN RINO 120 AND THE BATTERIES GO DEAD VERY QUICKLY. YOU CAN USE IT OUNCE TURN IT OFF AND THE NEXT TIME YOU USE IT THE BATTERIES ARE ALMOST DEAD.ALSO IT LOSES SATELITE SIGNALS AND TAKES A LONG...
An older unit. No service available from Garmin as it is obsolete. The 120's have a lot of problems. Poor battery life. Poor reboot and constant dying after on. I would find another unit.
Aug 10, 2017 | Garmin Rino 120 GPS Receiver
Garmin 760 not charging or working from the car charger. I changed the fuse and the green light is on but will not power up. It use to automatically come on when the car started and turn off but now,...
Since the unit will operate after charging - but only briefly - the battery in the 760 may be depleted. You can purchase a replacement that is as good or better for less than $25 from many places - here are the results of a google search. Some include the required tools in the purchase price.
Once you've got the replacement battery, you'll need to replace it. Check this link for the procedure. No soldering required!
Of course, you could send it off to Garmin, where they'll likely send hope this helps!
Oct 19, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Low battery display comes on when it is turned on then it shuts off its self
If this occurs when running on battery power, then it sounds like you just have a dead/bad battery.
If your GPS works fine when connected to a power source, then leave your GPS plugged in to a power source over-night, and if you still have this problem...
You can check to see if your device was included in a recent battery-related recall here:
https://my.garmin.com/rma/recallLanding.faces
If your unit is not included in the recall and you are (or a friend is) handy, you can buy a replacement on the net and replace it yourself for around $25 (US Dollars):
http://vimeo.com/8387716
(There are other sources for the battery, I do know if the linked company is trustworthy.)
I'm not sure what Garmin charges for this type of service?
Oct 11, 2010 | Garmin nuvi 750 GPS Receiver
I turn it on stays on for couple of seconds and shut back down, a couple of times it say battery is low, has been hooked up to 12volt power connecter in my car for close to 2 days
Your Nuvi 760 needs a new battery: rechargeables don't last forever.
Garmin's hope is that when the battery fails then you'll buy a whole new Garmin or will send it to them to be replaced, but it's a straightforward task to do yourself. Buying a new unit might make sense though if your unit also has outdated maps and/or outdated traffic/speed camera subscriptions.
A number of online suppliers have suitable batteries and there's more than one YouTube video showing you how to replace the battery. Click here for an example. Note that the same battery is fitted to the identical Nuvi 770, the only differences between the models is that the 770 has a larger internal memory to enable it to carry full US, UK and European mapping.
Please take a moment to rate my answer.
Mar 08, 2010 | Garmin Nuvi 760 Car GPS Receiver
Garmin 120 just dies
hi
have you put fresh batteries in
are they the right way around
are the 2 metal spring clips tight up against the batteries
try bending them (al little) to make better contact
has the unit had any water in/on it
is the mic button pushed down and draining the batteries too quickly
D
Nov 21, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
939 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
