Question about RCA HD61LPW165 61" Projection HDTV
61" RCA Projection TV, no picture, "unusable signal" message
Our power went out and when it came back on we couldn't get the cable going (kept getting a "unusable signal" display). We reprogrammed back to correct input, but only get a few seconds of sound, then it stops and goes back to unusable signal message. Comcast came out and spent an hour and a half and couldn't fix it. They said it was the TV because the same thing happens when he tried the VCR, a couple seconds of sound, then "unusable signal" again. He suggested resetting back to factory specs, but we don't know how.
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Posted on Apr 04, 2008
I have a 52" RCA
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
Feb 17, 2011 | RCA HD61W140 61 in. Rear Projection...
I see someone else has had a similar problem(Jun 15,2010), but no solution posted yet. I have a monster surge protector. It worked the first night that we lost power. I reset it and everything was fine....
Unplug the tv and the cable box about an hour,replug both devices back in.The cable box will reboot itself and upgrade it softwares.The tv should have signal again and work.
Jul 16, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Power went out, now screen shows bad or no signal,
U have cable or a satalite boxes?U have drop incomming signal.Unplug,replug about an hour later,let the boxes reboots,than ur signal will come back.
Jun 14, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Unusable signal is being displayed on television although it is connect to a digital cable box. It gives the same error even when connected to an analog cable box
You will need to have the tuner checked out, try connecting your cable box using the audio/video inputs to your tv(vid1, vid2 etc.)it should give you a normal picture.
Jan 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
What part do we need to replace?
check the power control board
thencheck thevideo controlboard
May 01, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
My rca tv
im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
May 10, 2008 | RCA P61960 61" Rear Projection Television
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Dec 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
RCA HD61LPW165 61" Projection HDTV Logo
908 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
