HP LaserJet 3600n Printer Logo
A
Anonymous Posted on May 18, 2010
LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
How can i fix 59.C0 printer error hp lj 3600
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Oct 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4760
Points
28
I have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Sep 17, 2010
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795126
Points
2925
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps. The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly. The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more help
http://www.fixya.com/support/t1517115-error_code_59_c0_in_hplaserjet
3 Related Answers
Anonymous
  • Posted on Feb 20, 2010
SOURCE: hp color Laserjet 5550 59.C0 printer error message
hp_color_laserjet_5550_59_c0_printer
Michel Smith
  • 1218 Answers
SOURCE: 59.c0 error in hp clj 3505 printer
The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more information....
http://www.fixya.com/support/t503092-59_c0_error_hp_color_laserjet_5550
seeker5211
Seeker5211
  • 1089 Answers
  • Posted on Mar 05, 2011
SOURCE: Problem Error Code 59.FO For HP Color LaserJet
If you haven't taken your printer apart, somehow the "cams" in the developer drive assembly worked their way out of alignment.
Somebody trained is going to have to align and calibrate the main drive assembly.
2helpful
5answers
Display showing error 59.C0 on Hp Colour lasejet 3600 printer
59.C0 ERROR
An error occurred with the developing separation-drive assembly.
1.Check that the following connectors on the driver PCA are seated correctly: J403, J405, J213.
2.Check that connector J1020 on the DC controller is seated correctly.
3.Check that connector J5008 on the fuser motor is seated correctly.
4.Replace the developing separation-drive assembly.
5.Replace the memory-controller PCA.
6.Replace the fuser.
1helpful
Problem Error Code 59.FO For HP Color LaserJet 3600 Printer
Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
1helpful
2answers
Hp Color LJ 3600 continue. Calibrating
Had a similar problem with a customer's printer. HP tech support had me change out the environmental sensor and the boards, this did not fix problem. In the end we had to get a replacement printer (thankfully the unit was under warranty)
3helpful
HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
6helpful
Error 51.23 on HP 3600 color laserjet printer
k24674
Grand Canyon Tech
Grand Canyon Tech
