A 52" RCA big screen that takes between 3 and 5 minutes before the color appears and then is fine. Came with the house I purchased so I'm not sure if I should have someone come look at it or is this normal?
  • 149 Answers
Model Please
Posted on Apr 03, 2008
I have a 52" RCA HD. I turned it on and for a few minutes it played great. Now the screen appears warped on the top and bottom.
This is a 52" RCA DLP projection tv correct?Yes,than a problems,u have is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 14, 2010 | RCA Televison & Video
Picture/color distorted
If the picture appears as 3D thats a simple and inexspensive repair. You can get the repair kit for your RCA Called "The ITC222 and ITC222A convergence option missing repair Kit" from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Dec 25, 2009 | RCA D52W19 52" Rear Projection Television
Sansui Projection TV - RCA D52W23 52 in., Problem is tv gets turn off automatically after few minutes. It doesnot off but a blue screen with lines appears immd.., it takes long time get the picture on...
CK for Bad capacitors cp114,120,150 if any of them is puffed up on top it is bad so replace all 3 cp150 is 2200uf 16v other two are 220uf 35v also resolder all pinns on FBT flyback transfomer.
Jan 23, 2009 | RCA D52W23 52" HDTV CRT TV
Projection on the screen is too large so the pic is cut off
using the right or left arrows should change your screen sizes 16.9 4.3 and so on
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
Rca big screen model p52939
If you cannot get a good convergence then the convergence modules need replacing.
Jun 20, 2017 | RCA P52939 52" Rear Projection Television
RCA HDTV 52 inch television
If a DVD and the onscreen menu looks sharp and problem free, I would say it's the cable box. Since you only reset it, I doubt it has anything to do with the cables unless you removed them and didn't insert them properly or tight enough. Try a power drain on the cable box:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. This will also reset the cable box again, but draining the power can do wonders.
Oct 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
