Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Video flickering My Akai is 3 yrs old. Recently develops heavy flickering on the screen that renders it un-watchable. Horizontal lines. After turning it off for a while, picture is OK but after heating up starts flickering again after about 15 min.
    Scholar:
  • 52 Answers
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Posted on Apr 21, 2008
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Two horizontal lines going across the screen
hi i have the same tv mine just started doing this last week were you able to fix the problem if so wht was it
Dec 02, 2012 | Samsung PN50B550T2FXZA PN50B550 50 Plasma...
I have a LG 32LD350 which is like 1.5 yrs old. when i turn it on the screen is all black, but then after like 5mins. there come the picture but it has a white horizontal line across the screen. then it...
Try changing the input device to something you are sure works. If problem persists, it can be due to dry/leaky capacitors and/or dry solder on PCB. Anyhow, this might then require attention by a qualified service technician.
Jul 25, 2012 | LG 32LD350 32 in. LCD TV
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Horizontal lines across the top of the screen
it is a fault in one of the capacitors in the vertical part of the schematics it is 33uf -160 volts capacitor , dry out and need to replace refer to qualified , regards , plz don't forget to rate thx
May 02, 2007 | Toshiba 27A44 27" TV
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal lines traveling up screen
Sounds like a ground loop on the video signal. Try using a ground lift on your computer and or your projector.
Jan 09, 2007 | Sanyo PLV 70 Multimedia Projector
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
285 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
