Question about Hyundai L90D+ 19" LCD Monitor
Anti theft mode
My original computer had problems so i changed my monitor to my other computer but now the screen has anti theft mode displayed. how do i change to a normal mode of operation
  • sjuanie Dec 14, 2008
    Hyundai L90D+ running windows xp sp3, NVIDIA GeForce 9600 GT video card. I had a power outage while I was gone and the monitor entered THEFT DETERRENCE MODE. No problem except the imagetune software for whatever reason, the plugin icon doesnt work, none of them do. I unistalled and reinstalled, no good. Without that I have nowhere to enter my pin# to get me out of this mode. I googled, tried ther website etc. I am wondering if the software may be conflicting with the NVIDIA software, of course I have yet to find the install disk for it or else I would uninstall that too and see if it works.
    Thanks,
    Steve J
  • Steve Si
    Steve Si May 11, 2010
    It would help us to know what make and model the monitor and computer are?
    Sergeant:
  • 395 Answers
If L90D you need a PIN number to unlock it.
Connect to your original computer and run Plug-ins - Theft deterrence to enter or reset PIN - or go to web site via software - see below
http://www.hyundaiq.com/Eng/DownLoad/MonitorDri/View.asp?page=1&SchSel=&SchStr=&idx=87&V_nm=30
Under the ‘Plug-ins’ menu is the ‘Theft Deterrence’ option – a more accurate term than the ‘Anti-Theft’ sticker on the monitor itself. Why? Well anyone can physically steal this monitor from me. There is no Bond-like lethal gadget that would bring certain death to a would be thief. Rather, the theft deterrent is a PIN-based procedure that hinders the operation of the display once it has been removed from the host computer. Briefly, you register and store a PIN to a secure web site, then set a countdown timer. If the power and display cables have been removed and the monitor has been attached to a different computer, the timer counts down. If the correct PIN is not entered using ImageTune, the monitor will enter theft mode and display a large warning message. It doesn’t prevent the monitor from being swiped, but at least there's some satisfaction in knowing the thief can’t use it.
software called ImageTune that replaces the usual on-screen display (OSD) tools, arrives on an included CD. With it, you can adjust basic monitor settings such as brightness and contrast with a mouse instead of with the small, squishy membrane buttons under the bezel.
Posted on Aug 10, 2008
Monitor mode
that is normal notification, which means your monitor doesnot support to higher resolution. so change screen resolution to 1600x1200 to fix this problem.
Mar 24, 2014 | Computers & Internet
Tip
Gateway LCD monitor EZTUNE theft protection problem
You need to install EZTUNE but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
on Apr 14, 2010 | Computers & Internet
My 19" monitor has the
Turn off the monitor, then while holding the 'menu' button, turn the monitor back on
May 29, 2011 | Acer AL1916W 19" LCD Monitor
It makes a blue screen every 20 minutes and says anti theft alert so i unplug it for about 5 minutes and then it works and does it again
To turn off anti-theft mode:
1) Turn off the monitor
2) Press and hold the menu button
3) Turn on the monitor
Release all the buttons
that should disable the anti theft mode
Mar 13, 2011 | Acer G185HAb 19" LCD Monitor
My lcd mode no HP L1750LCD a massage seems on my screen that theft mode enabled, as such it is requested that kindly solve my problem.
Hi, you can solve your problem to follow these instructions.Open the HP Display Assistant.
  1. Click the Plug-ins tab.
  2. Click the Theft Deterrence button.
  3. Click the Disable Theft Deterrence button.
Good Luck
Feb 24, 2011 | HP L1750 LCD Monitor
How to disable anti theft mode
By opening you anti virus from setting you can change the disable the anti theft mode from max 15 min to 2 hours
Aug 11, 2010 | Acer AL1916W 19" LCD Monitor
How to disabled the anti theft mode in acer monitor please solve this problem
Turn the monitor off. Hold in the menu button while powering back up. This permanently disables Anti-theft mode.
May 04, 2010 | Acer AL1916W 19" LCD Monitor
He message is ANTI THEFT MODE IS ENABLE. When it
try to go to bios by pressing f2 on start ..and after that choose optimal factory defaults from the list ...it will be somewhere there a line named exactly like that ..after chooseing it ..press f10 to save changes..and reboot ...if it set from there it will go away..
Mar 27, 2010 | Acer AL1916W 19" LCD Monitor
Anti theft mode enabled
you must trub off ur monitor power button on the monitor...
next step is on monitor u can see menu button we must press it and now we should press power button
now ur moniior anti theft mode will be disable
Mar 08, 2010 | Acer AL1916W 19" LCD Monitor
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
724 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
