Flash drive did datatraveler 100 twin pack kr-u061g02-1eq work with window xp?
  • phun2008 Apr 03, 2008
    no thanks
    Sergeant:
  • 202 Answers
Hi phun2008
Did your question get answered? (I'm not sure what "no thanks" was in response to.)
Your flash drives should work fine w/ Windows XP. They should be detected by the operating system as mass storage devices - plug-n-play - w/ no need for drivers installtion, etc.
You may, however, experience detection issues w/ them on systems w/ older USB hardware. If the flash drives are USB 2.0 drives, they will not be detected on systems running USB 1.1 or earlier - regardless of the OS (operating system) installed.
On the other hand, if they are USB 1.1 flash drives, they should be detected fine on both older and newer USB ports as USB 2.0 is "backward compatible".
I hope this helps.
BJ
Posted on Apr 03, 2008
  • Anonymous Apr 03, 2008
    Actually, that wasn't entirely correct (regarding USB 2.0 devices on a USB 1.1 interface).
    In most cases, your USB 2.0 device will be detected fine on a USB 1.1 port. You'll just be notified that the device could run faster on a high speed USB port rather than the one it's been detected on.
    It is on the USB 1.0 ports that you will definetly encounter problems when trying to connect USB 2.0 devices.
    My apologies for any confusion.
    BJ
SOURCE:
I purchased a Kingston DataTraveller 64gb hyper x 3.0. It works find on my notebook with windows 7 - fine on another notebook with Win xp - but when I plug it into my desktop system it flashes once -...
try going to this link might be something very simple but they have good information. http://www.kingston.com/en/support/technical/products?model=DTHX30 could be a case of being a usb configuration problem
Oct 20, 2013 | Kingston Computers & Internet
Tip
Windows Password Key 8.0 is considered as the best tool to reset local...
You can change a Windows User Account password that is on any Windows computer from any other Windows computer regardless of whether the User Account is on a workstation, a stand-alone server, or a Windows domain controller. Additionally, it makes no difference whether the password being changed from a workstation, a stand-alone server, or a Windows domain controller. This is true for any NT 4.0, W2K, XP Pro and Windows Server 2003 computer.
To change a user's password at the command prompt, log on as an administrator and type:
net user danielp * /domain
(This is only an example, use your own username)
When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user danielp 123456 /domain
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Note: If you type these commands on a member server or workstation and you don't add the /domain switch, the command will be performed on the local SAM and NOT on the DC SAM.
on Apr 28, 2010 | Microsoft Windows XP Professional SP2
NEED DRIVER FOR 8GB datatraveler 101
Windows has built-in support for usb drives. If your flash drive isn't showing up under "Computer/My Computer" then there is a problem with the flash drive.
Dec 17, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Kingston datatraveler 410 can not log in
you might be better using a computer with xp to save your photos to another device or even burn them to a disk
windows 7 i have found if i use a data traveller on xp then try to use it on windows 7 it will always say it needs to be formatted do you want to format now
so i have designated certain data drives to my xp and others to my windows 7 although i have found that i can use small ones on each computer 1gb to 2GB
if you right click in the bottom toolbar when this is happening select task manager under applications you will see whats running if you dont want it to be running select end now also under processes see whats ticking over the same will apply
if you can get it to be recognised it might ask to be formatted
hope this helps
Feb 19, 2012 | Kingston Computers & Internet
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
Activision sega twin pack 2 will not install to my computer.
No fix. Not Written for Xp.
Wikipedia
In 2002, Sega Smash Pack: Twin Pack was released on PC, and it contained both of the above collections. However there are incompatibility issues as a result of playing the game on Windows XP. When a user plays Sega Smash Pack 1 under XP, Games suddenly quit without error after a certain amount of time.
Dec 27, 2008 | Computers & Internet
DataTraveler 4GB
You can use with Windows2000 and up and other operating system, you ca check this link for the complete information about this device http://www.kingston.com/ukroot/flash/dt_secure.asp?id=2
Hope that helps...........
Oct 01, 2008 | Kingston Technologies 512MB DataTraveler I...
W98SE Driver for Kingston 1.0Gb DataTraveller Flash Drive
The people at your local computer shop are wrong but, Windows 98 should at least recognize the USB thumb-drive and ask for drivers.
I would remove all the USB Controllers from within Device Manager and restart; allow Windows upon restart to reload the USB Controllers; then plug in the drive and see if Windows at least recognizes and then install drivers.
It seems only the DTI/XX, KUSBDTE/XX, and DTII/XX support Windows 98.
Dec 04, 2007 | Microsoft Windows 98 for PC
Open Questions:
Computers & Internet Logo
107 people viewed this question
Ekse
Alun Cox
