Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Gas Trimmer will not stay started
I just pulled out my Ryobi Gas Trimmer from winter storage and when starting, it will start on Full Choke, and sometimes will run on Half Choke, but when I move it to Run or pull the trigger it quits running. I put new gas and mix in it... What can this be??? Please help.. Dano
  • 1 more comment
  • Anonymous May 26, 2008
    I can start my Ryobi trimmer and it will idle, but dies when the trigger is pulled. On half choke, it wil rev briefly when the trigger is pulled, but dies shortly afterwards if I do not switch it back to full choke briefly. The filter looks good, new gas/oil did not help.
  • ZiggyzPaw Jun 16, 2008
    I have the same problem. It started when I rotated it 90degrees counter clockwise. Now, the same day, it jsut dies when I squeeze the trigger. Anyone know of this problem or of a recall? Thanks! Send answer to Firechef@cox.net
  • chm799 Jan 30, 2009
    My RY30544 Trimmer will only start and run when set on full choke and dies when I pull the trigger.
My straight shaft trimmer will idle but dies when the I pull the trigger.
Posted on May 18, 2008
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Jun 27, 2010 | Garden
Can't get my Ryobi CS30 trimmer started, bought a new spark plug, still won't start. It worked fine last summer, took it out for the first time today, won't start, has plenty of fuel
Is the fuel old or has it been drained and refilled?? Sometimes old fuel will do this. Also make sure the air filter is clean and free of oil/dirt as this will also hinder the starting.
The primer button also is something to check. Push it 7 times, full choke, pull for 5 times, turn to half choke, and the unit should start.
Let me know,
Chip
Apr 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Lost manuel Can't start my Ryobi C530 gas trimmer
trun the on/off switch on,prime it with the bulb 3-6 times choke it , pull the cord 1 or2 times then take the choke off and pull a few times till it starts if it doesnt start you have problems.
May 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Have a similiar problem with a John Deere trimme (T 105C) and was told by the dealer that it is a carburator problem and would need to be replaced. Cost of the part is $105.00 plus labor. Not worth it to pay to buy the part & have it repaired. Good luck.
Sep 29, 2008 | Garden
Problem with gas trimmer staying started
Carburetor is out of adjustment. there are two carb adjustment screws on the side of the Carb. they require a special tool that is only $5 from your local mower repair dealer. those screws are the idle and Hi speed mixture adjustments. the carbs on Ryobi are set too lean. turn counterclockise to richen the mixture. just turn one eigth of a turn at a time. start w the hi speed.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,746 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
