Question about Samsung Digimax S630 Digital Camera
Red eye button when I try to snap a picture
I'm unsure if a setting is wrong or what but my 10 yr old used this camera and now when I try to snap a picture,I get a red eye button on the left side of the screen when I try to snap the pictures.
    Problem Solver:
  • 15 Answers
I believe that's your flash setting. Just press to the left of the Menu/OK button to change the flash setting.
Posted on May 14, 2008
How do you turn the flash off so I can take pictures where a flash cannot be used?
Press Right on the cursor button (marked with the lightning bolt icon) to switch the flash setting. Your choices are AUTO, AUTO/Red-eye reduction, Forced ON, Forced ON/Red-eye reduction, Slow sync/Red-eye reduction, and Forced OFF.
Apr 19, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
I can't find my manual for my ex-z80 camera and am getting red eye and blurry pictures. How do I set these correctly?
Visit this link to download manual for EX-Z80.
Try to reduce the red eye function or try resetting the camera to the Default Factory Settings by performing the following steps: 1) Power on the camera in REC mode. 2) Press the MENU button. 3) Select the SETUP tab. 4) Scroll down to RESET, use RIGHT arrow and select RESET again. 5) Press the SET button.
Good Luck....don't forget to rate the solution.
Feb 28, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Nikkon coolpix l10 won't snap picture
hi there
just an idea the big multi button with the ok in the middle
press the 3 o'clock bit with the mountain symbol on it (while in camera mode) it should say auto but if it doesn't use the 12 o'clock and 6 o'clock keys to select auto then press ok in the middle.
hope this helps
Oct 07, 2008 | Nikon COOLPIX L10 Digital Camera
Camera flash
No worries, I think I can help you with this one.
I believe that if you are using your Samsung Digimax in either "Auto" or "M" mode you will only have the options of "red eye flash" or "no flash". BUT HOWEVER, if you select the "Prog" mode on the dial on top of the camera, you will have 4 flash options - "red eye flash", "auto flash", "slow flash" or "no flash".
I hope that this helps!
Oct 02, 2008 | Samsung Digimax S600 Digital Camera
I have a canon powershot 750
An ideea would be pressing the button a little bit harder and a little bit longer.Most of the cameras have that orange light before the flash(that appears when you press harder on the button) to reduce the red-eye effect in the pictures.
If this doesn't work, look carefully in the manual or the settings of your camera and try to find an option that turns on the flash.Also the type of the picture(indoor, sunny, night etc) can automatically disable the flash.
As a last resort, here is the camera's manual
Sep 02, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Red Eye
i have a suggestion,
you can use Picasa2 to get rid of the red eye from your pics. however, this is installed on your computer and whenever you will take pictures, there will still be red eye. Picasa2 is very easy to use and you can get rid of the red eye in only matter of seconds.
download Picasa2 here
Apr 01, 2008 | Sony Cybershot DSC-T200 Digital Camera
Delay in taking pictures
Shutter release button has two positions. Auto focus function activate first when u press butten halfway(u can see a focus indicator icon with beep sound).Now if u press it some more, camera will take snap at earliest .So pl confirm the subject to be focused by keeping the button half way pressed then press it some more at the right moment.Also cancel the red eye reduction function when u r using flash because it creates more delay .
Nov 26, 2007 | Canon PowerShot A540 Digital Camera
Red eye reduction
while in record mode, press the flash/up button repeatedly until you are in red-eye reduction mode. red-eye reduction mode should greatly reduce the problem when enabled. If this does not work, the software that came with your camera (and most photo editing applications) include a red eye reduction/removal filter.
hope this helps,
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
DSC-P72 using Flash
Hi, While I do not have a P72, I find this problem odd. Most flash cycle times are so rapid that your grandaughter could not possible close her eyes in that time period (the travel time for the flash to fire and be reflected from the child's face is far faster than a human blink). The problem may be in pre-flash and not the flash itself. So that redeye-reducing "feature" may be responsible for your problem. Does your camera have a redeye reduction mode on the flash?
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Samsung Digimax S630 Digital Camera Logo
66 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
