Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
My computer keeps rebooting itself.
A few evenings ago I was working on my computer (emachine) with no problems. The next morning it was frozen with on 'countdown' screen to reboot. I had to hard boot to get it to do anything. When it starts booting, the E logo comes up with my options to go to bios etc.... then it goes to the countdown screen. Whether I chose to boot normally or using last good config, it would just repeat the process of going to E logo screen. I got frustrated and turned it off for most of the day. When I turned it back on, it did the same thing, but this time when I chose last good config it actually start booting up. There was a microsoft error report, so I sent it. I tried to go download a critical windows update, but at approx 75% completion....it rebooted itself. This started the cycle over, however I was having much better luck at least getting it to boot all the way at least a couple of times, so that I could back up some recent files. I tried to restore, but it never seems to get to complete either. Essentially, at this point, I can get it to boot up, but if anything is running it won't take it long to start rebooting itself. Sitting idle it takes it longer to start rebooting. Please help! I had some power issues in my office at home today which caused my computer to keep turning on and off a few times. I moved my computer to another location within my house to avoid voltage/wattage problems in that room. It still is rebooting over and over, even if I click any safe mode options, normal start, or last configurations. I opened the tower and cleaned everything of dust. The fans work properly. Did my computer become damaged with the power from the outlet turning on and off many times? Please help. Thanks.
  • 5 more comments
  • tigertony Apr 03, 2008
    Actually, I messed up on the comment area when I signed up. My comment is the second comment by tigertony, the first was submitted by another member. sorry for that.
    Hello Psionics, I read your comment above and checked all capacitors for bulging or leaking as well as anything that would be considered irregular that I could visibly see. One thing I'm not willing to do at this point is erase my hard drive. I have pictures and documents I have not backed up yet, unfortunately. After watching the reboot process a bit more, I decided to press my f5 key and it brought me to another screen which gave me more options. I chose to not auto start or reboot to see if it would windows. A blue screen popped up (that I couldn't halt before because it kept cycling), and states the following: A problem has been detected and windows has been shut down to prevent further damage to your computer. UNMOUNTABLE_BOOT_VOLUME
    disbable or remove any newly installed hardware or software. Disable BIOS memory options such as chaching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press f8 to select Advanced Startup Options, and then select Safe Mode.
    Technical information:
    *** STOP: 0x000000ED (0x82F45900, 0xC0000006, 0x00000000, 0x00000000)
    I'm not very computer savy to say the least, but I'm willing to learn, here and there. I don't understand most of this information or really how to apply it. Based on this information above, can I still save my hard drive from extinction? Thanks.
    Comment by tigertony, posted on Apr 03, 2008
  • tigertony Apr 06, 2008
    I'm having difficulty finding my windows xp boot cd. Until then, I'm stuck for now, unless I can get one from somewhere else.
    Thanks. I will try to locate a xp boot cd somewhere. As a last resort I will engage my system recovery feature.
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    When you say "tried a restore" did you do a windows repair or complete re-install?
    New Friend:
  • 161 Answers
I would try taking to motherboard battery out for 10 minutes to reset the bios.....then try booting again.......if not then the bios could possibly be fried.....i had teh same problem with a computer i built myself......
Posted on Sep 30, 2008
  • 61 Answers
This is almost certainly a software issue, probably malware. load it up in safe mode and attempt to scan it for virus' and malware. use something professional like malwarebytes.org, spybot search and destroy, Norton, Kaspersky and mcafee and always try multiple scanners as no one scanner will get it all. there is also a good free scanner over at trendmicro which will also remove malware.
Posted on Nov 08, 2013
Try chkdsk /r with windows recovery this should solve the problem
Posted on Jun 10, 2008
  • 236 Answers
It is not very likely that your computer was damaged, but if you want to make sure, check for any leaky capacitors/burn marks/dark areas on the motherboard..
Look for things like:
My computer keeps rebooting itself. - 238799e.jpg and
If you can't find any, the mobo is fine.. which is a good sign..
Next, I would try re-installing (not repairing) the OS by using the windows CD that came with your system.. If you did not get one, there should be a recovery drive on your PC (CAUTION: this will erase everything on the drive)....
The fact that your computer fans and everything else come on indicates that it is probably not the power supply, so we'll leave that alone for now...
It could be that the RAM was damaged.. i'm not too sure how much you have installed, but that pc may come with 2 sticks of ram.. if that is the case, try each on on it's own and see if that works..
Sounds more like a software issue, and if re-installing windows does not work, I would suggest buying a new Hard-Drive.. (if that doesn't fix the issue, you can always return it)...
If none of these things help, let me know and I will try to help you more...
Posted on Apr 03, 2008
  • 9 more comments
  • Dave MacPhee
    Dave MacPhee Apr 04, 2008
    You can try going into safe mode. It really does sound like a windows update caused the problem..
    In safe mode, try uninstalling the last few windows updates (on and just before the date the errors started occuring).. some updates have been known to cause problems, and are later fixed by another update..
    See if that helps any
  • Dave MacPhee
    you could also try a repair windows from your windows boot cd.. That will not erase the contents of the drive, but you will have to re-install any additional software you installed after you got your system...
  • Dave MacPhee
    Also, before trying the repair option.. When you boot from your Windows XP cd, choose the recovery console. Once in there, choose your C:\
    once at the prompt, type chkdsk /r
    That may fix any issues as well.
  • Dave MacPhee
    Dave MacPhee Apr 06, 2008
    Any updates?
  • Dave MacPhee
    did your system not come with a recovery drive built in?
  • Dave MacPhee
    You can also use another XP cd (from a friend), or, if you have a floppy drive on your system (may also work from CD) download THIS from microsofts website
  • Dave MacPhee
    sorry, that file will let you boot from floppy, without having a bootable cd-rom drive..
  • Dave MacPhee
    If you have access to another system (which obviously you do) you can download UBCD4WIN and created a boot CD from the local harddrive.
    Download from here
    Follow all the instructions under "how to build".. you may have to slipstream a service pack into the installation, but there are instructions and links to programs on that site.. Most of the time, if the computer you are using does not have a boot CD, you can find the windows files in the C:\I386 or c:\windows\System32\I386 folders - copy those to another location on the harddrive, download the service pack you have currently installed on your system (the one having errors) and use the slipstream program if you need to add a service pack.
    Setup is a little daunting at first, but if you follow all the instructions carefully, it will work
  • Dave MacPhee
    problem is, that Media Center functions are not easy to restore, and may not be restorable. But at least you will have a running copy of windows on your system.. (If you do a fresh install of Windows XP on your system, and not Windows Media Player, you can still use the same product key located on the back or side of your pc)
  • Dave MacPhee
    after thinking about it, you should have a recovery drive.. To see if you do:
    Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
  • Dave MacPhee
    Dave MacPhee Apr 08, 2008
    if you do get into the Recovery, you can do a non-destructive restore..It will not delete all the files on your drive, but you will have to re-install any added on programs/applications after you first got your pc...
    Also, just as a side thought..Did you try using the RAM one stick at a time?
2 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: My computer keeps rebooting itself.
First check the cmos (3V disc shape)battery on your motherboard is ot flat, as this causes reboot loops. Also check that the processor fan is free of dust and so you can count out overheating.
Posted on Jan 02, 2007
Why my tablet wont let me select the next button....its frozen
The only thing I can suggest is to disconnect everything and remove the battery for a few minutes. Then, reinstall the battery, connect your cables and reboot, in the hope that everything will reset itself.
Jul 02, 2014 | ASUS Eee Pad TF101B1 Tablet
My emachine will work great for an hour or so and then it automatically reboots itself
Check the event viewer to see if its spitting out a Critical error or warning. This might help you further troubleshoot why it keeps rebooting.
Mar 08, 2013 | E-Machines eMachines Desktop PC
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
Computer comes on and is fine for a while then just cuts off,then turn it back on then its fine for a while then cuts back off.
Hello
To start with, you should check all your hardware. A loose connection somewhere or a faulty piece of hardware could be the reason, the computer keeps rebooting itself. In case your RAM stick is not fitted properly, or is corrupt, the computer displays an error message on the screen and keeps rebooting itself. The same problem occurs with a hard disk. You can use 'Memtest86' to run a hard drive check.
You may at times come across an error message on your screen, like a system failure error, before rebooting by itself. There is a particular solution to this type of problem. You should first go to the My Computer icon and right click on it. Select properties, and a window will appear on your screen. Click Advanced tab → Start Up and Recovery → Settings. After clicking the settings option, you will have to uncheck the box next to Automatically Restart. Click OK twice. This will prevent the computer from rebooting itself and you can redress the issue.
A different way to tackle the problem of 'computer keeps rebooting itself', would be to restart your computer in the Safe Mode. Allow the computer to boot fully and let your windows operating system load fully. Now, if your computer keeps rebooting itself even in the safe mode, there is a problem either with the operating system or hardware. And if your computer is not rebooting itself in safe mode, the problem is related to certain software.
Over heating is another reason why your computer keeps rebooting itself. Not many people pay attention to this aspect though. The fan responsible for keeping the CPU cool, may be malfunctioning or there could be dirt settled between the fan and CPU. Any one of these could be the reason for your problem. Either clean the fan area, or replace it if necessary. Try providing proper ventilation for your CPU, so that it stays as cool as possible.
You computer could reboot on it's own if you have installed improper drivers. Right click on the 'My Computer' icon, and click on 'Properties' from the menu list which appears. A new window will open. Select the 'Hardware' tab, and click on 'Device Manager'. A list will be displayed on the screen in which you will have to check all categories. Is you see any red or yellow warning icons, make sure you update that particular driver from the internet.
Dec 13, 2010 | Computers & Internet
IPhone 3G shuts off by itself
Try replacing the battery. Also check to make sure that the battery itself is secure and can't move within the phone casing.
Oct 02, 2009 | Apple iPhone 3G
Emachine reboot problem
First of all remove ant cd from drive when booting up uinless you are using a bootable windows disk. if the problem still persist when then computer starts booting up keep pressing f8 until you get the choice to go in to safe mode. Once in safe mode choose the option when prompted go to system restore points and restore the computer to a date availabe wich is before the date of the problems.
Aug 19, 2009 | E-Machines eMachines Desktop PC
I ran into a emachine desktop 3 days ago, and reinstalled operating system, everything was working fine, however when i shut down and booted the next day, computer continued to reboot itself after passing...
there is usually a jumper with three pins beside the cmoss battery just move the jumper to the last two pins for 5 seconds and put it back that will reset your bios that may help
Apr 18, 2009 | Computers & Internet
Won't Stay On
http://www.laptoprepair101.com/laptop/2006/04/06/satellite-m35x-a70-a75-lockup-freezes-reboots/comment-page-7/
May 19, 2008 | Toshiba Satellite 1115-S103 Notebook
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Jan 02, 2007 | E-Machines eMachines Desktop PC
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
6,621 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
