Question about NAD C720BEE Receiver
Receiver fuse continuosly blows when replaced and powered up
I am having difficulties with my stereo receiver in which the fuse blows every time I have replaced it. I even uplug the amp in the case that this is somehow causing the overload to the fuse. I'm assuming that one of the resistors is bad or something of that nature. What do you think? Help is greatly appreciated :)
  • 20 Answers
When a fuse blows it indicates that too much current is flowing. This melts the wire in the fuse.
What is actually damaged is hard to say, remove all the cables and test. If the fuse still blows take the unit in for service.
I doubt that a resistor has died, more likely something has created a direct short. It could be a power supply issue, or an issue with the amplifiers.
Ask for a quote first if it is out of Warranty.
Posted on Apr 03, 2008
Ir's not likely to be a resistor. Sounds like a shorted component in the power supply. A diode or bridge rectifier, or possibly a transistor or Regulator IC.
Hope that helps...
Geno
How many amps is my RCA Sta 3850 am/fm stereo receiver and where would I find a fuse for it also what exactly could be making the fuse blow out?
I would like to purchase a Realistic STA-3850 AM/FM Stereo Receiver, anyone that would like to sell, please contact me at my email address: vfintd386@hotmail.com. Thank you-dave
Mar 24, 2012 | RCA Audio Players & Recorders
I have a Niles SW300 subwoofer that continues to blow fuses. I have replaced the fuse, but when it the power is plugged back in the fuse immediately blows.
ok, temporary cheap fix... (i mean in a ******* engineering kinda way ;-) . . . )
since your primary receiver has a sub-out RCA plug, you can hop into the local pawn shop, buy a cheap receiver and an RCA line splitter, and connect the primary sub-out to the CD or any input EXCEPT phono (resistance is different on the phono rca's). remove the plate from the sub and run the speaker wire from the "pawn stereo" directly to the speaker. replace plate on sub to keep box sealed, and adjust receivers to desired level of bass & volume.
You have spent $50 and now have a decent sounding system again.
Mar 27, 2011 | Audio Players & Recorders
Have a da555es stereo receiver. Fuses blow as soon as you plug it in to wall socket. Receiver is approx 10 yrs old and just started doing this. Any ideas?
If fuses blow out imediatelly its a sign that its something wrong in the imput area eg the power pcb or transformer pcb. try to see is there in its supply some electronical parts broken or some bad wire isolation.
Feb 18, 2010 | Sony STR-DA555ES
I have my jensen in a 2006 pontiac vibe. after leaving the dome light on all night, i boosted off the car and now my stereo won't come on! checked all fuses what's wrong? it was fine before.
There is a protection fuse in the back of the radio itself, sometimes in the wire comming off the radio. alot of times when boosting a car it will receice a power spike, and blow this fuse.
Aug 15, 2009 | Audiovox JENSEN VM8012 3" WIDESCREEN...
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
What type of fuse does the sony stereo receiver model number STR-DE597 have.
The main and I think only fuse is a gma 6.3v fast blow.
DO NOT Use a slow blow fuse it will cause more damage to your receiver!!! If it opened once it will probably open again.
Odds are a set of output transistors are shorted (MP1620 and a MN2488)
Jan 24, 2009 | Audio Players & Recorders
Have a nearly 30-year old Akai stereo receiver AA-R30. Power light just stopped turning on. Opened up case and found main fuse between AC power cord and power transformer blown. When I replace the fuse,...
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Apr 08, 2008 | Audio Players & Recorders
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
NAD C720BEE Receiver Logo
952 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
