Question about InFocus LP 600 Multimedia Projector
Projector completely dead, no power status light
Looks like the input power supply board is bad what is the estimated cost to have this replaced
  • Anonymous Apr 10, 2008
    where could I purchase the replacement parts to fix the power board
  • 563 Answers
Hi Johngm
It will be in the region on $50 - $70
Posted on Apr 03, 2008
My projector comes on and is totally fine but wont show a picture i can switch inputs and go to the menu but all i get is a blue screen help?
HI
YOU NEED TO REPAIR / REPLACE THE MAIN BOARD.
THE SUPPLY TO THE LCD PANEL CIRCUIT BLOCK MAY BE DEAD.
CHECK THE POWER SOURCE TO IT .WNA200 - SHARP CHIP FOR DEAD FUNCTION.
THIS SHOULD CURE THE PROBLEM , ELSE YOU MAY HAVE TO REPLACE THE BOARD!
CHEERS!
Apr 05, 2015 | Panasonic PT-AX200U Projector
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
My mitsubishi WD62528 projector tv is not powering on. when the tv is tuned on the timer light blinks for sometime before it becomes steady while the lamp light and status light is off. i sent a message...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, and do take care in handling the set
May 27, 2011 | Televison & Video
I have a Panasonic TH-50PX75U Plasma 50" tv. The
I had the same problem call sears it's only $99 to come out and free estimate. mine cost $300 and it works great. mine was a circut board had to be solderd back in
Dec 19, 2010 | Panasonic TH-50PX75U Plasma HDTV
My wife turned on our X1a and the whole thing died. She said she heard about half the normal "beep" before it completely shut down -- no LEDs, no fan, nothing. (I'm currently away with the military and...
the most inexpensive thing to change would be the power input board, which is what the plug plugs into, if that isn't the problem, you can look at the glass fuse on the power supply next to the input board to see if it is blown. if it is the fuse then the power supply needs to be replaced unless you know someone to desolder and resolder a thru hole fuse. Also, make sure the lamp door is shut properly. If the door doesn't push the safety switch in it will not complete the cicuit to allow power to the projector.
Jun 13, 2010 | InFocus X1A Multimedia Projector
My xr 10x lost power last night, stopped dead. No
make sure the lamp door is engaging the safety switch. if it is then the a/c input board is bad or the power supply.
May 15, 2010 | Office Equipment & Supplies
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Nov 09, 2008 | Sharp Notevision PG-A10X Multimedia...
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
InFocus LP 600 Multimedia Projector Logo
64 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
