Question about Dell 942 All-In-One InkJet Printer
Error 1203 on Dell 942
What did you do to correct your problem? Were you successful?
Thanks
  • 1 more comment
  • Anonymous Jul 01, 2008
    1203 error comes up on our dell 942 printer.
  • Anonymous Sep 16, 2008
    Error 1203, consult user guide; a computer tech told me to try cleaning the print heads, i think i've done that, but still the error comes back on...
  • Tracy Johnson
    Tracy Johnson May 01, 2019
    Dell Printer Error Code 1203 is a common printing error that is connected to the ink cartridge used in your printer. You can use any of the solutions mentioned below to fix the error:
    1. Use a wet cloth to clean the ink cartridge in your printer
    2.Disconnect the cables and reset your Dell printer
    3.Replace the cartridge with an original Dell ink cartridge
    4.Use the Windows Troubleshooting feature to detect and resolve any minor technical errors in your Dell Printer
    More:https://www.usahelplinenumbers.com/dell-...
We had our computer to crash and now have windows vista instead of windows xp. Our printer says error code 1203. We have cleaned the printer heads and we still cannot get our printer to work. Is the printer not compatable with windows vista? How can we fix this problem dee
Posted on Sep 23, 2008
SOURCE:
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
*6
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Apr 12, 2015 | DSC Wt5500 - Alexor 2-way Wireless Lcd...
C:\e867cc63c07bed2da\update\iesetup.exe
this is not an error code.....do a fresh install....this may correct...good success, meder's tv service
Jul 26, 2013 | Computers & Internet
My keyboard on my Sony Vaio PCG-5J2L is not typing the correct key what can I do?
dear mel, i would like to try and help you. is it an english keyboard? what keys wont work correctly? did you check the language/layout settings?
Mar 18, 2013 | Computers & Internet
My sound driver wont install successfully using Realtek HD Audio for x86 in ASRock Wolfdale I333 D667
Hi , x86 is 32 bit OS , make sure that your PC is 32 or 64 bit , aswell as which OS , Vista win 7 or XP ...Then download the correct one , and it should work.
Thanks
Dec 30, 2009 | Computers & Internet
Bulb position failure light message
a small flt blade screw driver you will have to try both ends but once you get on the correct end of lens the unit will pop out
Aug 16, 2009 | 2004 Volvo XC90
Ntldr is missing Did the restart command without success. Checked CMOS & Bios everything is correct. Tried to reboot from cd, no success. Tried F8 F10 F12 on start up failed. Could you please to...
Use the following link to help troubleshoot
http://support.microsoft.com/kb/318728
As you told the F8 ,F10 F12 is not giving you any success, do you mean to say the computer ends up going to Ntldr missing. Could you give me the maufacturer of your system
Thanks
proton
Oct 01, 2008 | Medion Computers & Internet
Flat battery-applied incorrect rdio code numbers found correct code no at home but radio will not accept it. tied disconnecting battery again -no success tried leaving radio turned on for 1 hour as per...
im sorry im having a little trouble understanding the ?tion, are you trying to remove the radio the correct way or install it and having trouble getting the code off the screen...
Aug 11, 2008 | Car Audio & Video
Dell 942 All-In-One InkJet Printer Logo
129 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
