Dont wash or spin
Hoover 700LD washing machine...does not wash or spin occasionally, problem getting worse...sometimes it will other times it wont
Peter
    New Friend:
Solution: Replace Control unit motor kit made by Electrolux with Part Number 0628271101. Buy online on Ebay.
Posted on Nov 10, 2010
    Sergeant:
  • 351 Answers
Check for a broken wire in the loom of near the motor
Posted on Apr 03, 2008
SOURCE:
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
HI We have a Hoover 700LD washing machine that wont fill or wash. Will drain and spin. Any ideas? thanks
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
Feb 05, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Hswf 147 hoover washing machine wont spin
Not spinning at all can sometimes be caused by a blocked filter or drain pipe. Does your machine spin if you turn the dial to the spin only setting? Ours has developed a fault whereby it won't spin at the end of a normal cycle, but if I turn the dial to 'off' then to 'spin only', it will spin.
Dec 11, 2010 | Hoover Washing Machines
WASHING MACHINE NOT SPINNING AT END OF CYCLE AND SOMETIMES REPEATS THE CYCLE.
check the turbine blades, maybe the wer'e loosen up. Try to refit that one.ok??
Jan 29, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Hoover top load washing machine
make sure thers nothing stuck in the pump and the pump is not faulty.somtimes a coin can get stuck in the drain hose causing it to not drain intermittently
Dec 21, 2007 | Hoover HTC243 Top Load Washer
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
Mar 12, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
310 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
