Question about MicroBoards (DX1DV100004) DVD±RW Dual Layer Burner
Microboards dx-1 printer burner
Do you need to have both the color and black ink cartridge installed for the printer to work?
    Genius:
  • 2,785 Answers
Most of the printer will not work if both the cartridge in not installed.so you have to install both the cartridge
Posted on Apr 03, 2008
SOURCE:
Microboard pf3 is not printing with NEW EXPIRED ink cart.(v101c black and v102c color). please how can i make it work
I had a HP that wouldn't print because the Cart. were past a certain date. I finally just went in to the pc and set the date back, and the Cart. worked fine.
Jun 02, 2014 | Office Equipment & Supplies
My printer Micorboards PF-PRO not print the yellow color, same with new ink cartridge
please follow the troubleshooting software with the printing. and make the test for clean it. etc.
Otherwise, the cartridge can be faulty.
God bless you
Nov 24, 2013 | MicroBoards PF-Pro Autoprinter Optical...
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the...
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Dec 23, 2011 | MicroBoards PF-3 InkJet Printer
Microboards pf pro refill cartridge
you can now get continuous inking systems for the microboards pf-pro machines
see here:
http://www.jpldisplays.com.au/catalog/product_info.php?products_id=4150
Mar 17, 2010 | Microboards PF-3 Print Factory Printer and...
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
Dec 07, 2009 | MicroBoards PF-2 Disc Printer
Install black cartridge, but will not print
Lets do it this way. Follow these steps again carefully and try to install the Ink.
Introduction
Follow the instructions below to replace the ink cartridges.
Replacing the ink cartridges
1. Verify that the unit is on.
2. Open the ink cartridge door.
3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
1 - Ink cartridge latch for the black ink cartridge
2 - Ink cartridge latches for the color ink cartridges
NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging.
6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
7. Press down on the gray latch until it clicks into place.
8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
9. Close the ink cartridge door. Print a test page.
If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
Shut down your computer and restart it.
Re-install the printer driver/software from the start as you did when you bought it.
Good luck
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black or Blue not printing - just red and yellow
Are you using geninue Microboards new cartidges or refills? If you are using the new Microboards ink carts, then you have a bad cartridge, or possibly a bad batch. Simply call Microboards tech support at 952.556.1639.
http://www.techwaredist.com
Oct 16, 2008 | MicroBoards PF-2 InkJet Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Microboards PF-2 inkjet scanner problem
I have found that a slight forward adjustment (actually, it was adjusted all forward, so I had to bend it)of the vertical post that holds the reader so that it is closer to the inkcarts-- but really have to be careful that you don't adjust too close, or else the carts might strike the reader. I moved the reader closer by about 1/16th of an inch-- that solved the problem. Too bad Microboards had installed this-- just to milk their own clients of their products. If there was another alternative, I'd be there. Just a note to others-- if the reader does not read properly, it will stop the feeding of the disks alltogether and you will have a flashing down arrow on the right and the red light on the left. I have resorted to having the carts refilled-- works great.
May 13, 2007 | MicroBoards PF-2 InkJet Printer
Open Questions:
See all MicroBoards (DX1DV100004) DVD±RW Dual Layer Burner Questions
MicroBoards (DX1DV100004) DVD±RW Dual Layer Burner Logo
187 people viewed this question
Top MicroBoards Computers & Internet Experts
kevin gabrik
kevin gabrik
Level 1 Expert
Marvin
Marvin
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
