Question about LG DLE2514 Electric Dryer
Longest 6 minutes ever
Dryer when in sensor mode counts down to 6 minutes and then stays there and never counts down or stops. It will say 6 minutes for the next hour untill I manually stop the dryer.
  • 5 more comments
  • bogi zab Apr 07, 2008
    Same problem with the lg2526w gas dryer . First time used.
    lg 2526w gas dryer, counts time till reaches 6 and works all the time showing the same time. Never stops. First time used.
  • Krazee Apr 07, 2008
    Same deal -- just started after owning dryer since spring of '05 -- "longest 6 minutes ever problem." Just doesn't count down so will not leave house with dryer running.
  • Tolt Apr 08, 2008
    Same problem with gas dryer LG2522. Bought dryer in October 2005. In sensor mode dryer counts down to 6 min then keeps on running forever.
  • nrbaker May 04, 2008
    Have LG 2514W since Feb 06 Just started April 08 freezing at 6 minutes. Does not do it on every load but way too often. I wonder what it cost to replace the circuit board if that is the problem.
  • SKW914 May 21, 2008
    I have had the dryer for about 24 months and it just started doing the same thing. I wonder if since this seems to be a common problem if LG will step up to the plate and replace for free even out of warranty???? Anyone know?
  • Anonymous Jul 03, 2008
    6 minutes - dryer does not shut off.
    It appears that after 24 months (give or take) the lint build up on the sensor located just inside the door has enough lint on the 2 metal strips or the 2 connectors (inside the grille) that the dryer still thinks there is moisture in the air.
    The easiest repair would be to blow out the grille assembly (just inside the door) with compressed air to be sure to clean the 2 connectors. The 2 metal strips can be wiped clean.
    The 6 minute point is just a programmed check point for the dryer to start counting down to stop.
    Replacement of any other part just sounds like a service support call.
    Champion:
  • 210 Answers
Check your complete venting system to make sure it is not clogged. Use a nylon scrubber to wipe down the 2 sensors as they can get coated with fabric softener, and clean your filter as it can get clogged too. To test it run it under water to see if the water goes through or pools. Use hot water and mild soap to clean it. I have heard some people put it in there dishwasher to clean it.
Sgt 48
Posted on Jun 07, 2008
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Posted on Apr 29, 2008
I unplugged the dryer to pull it away from the wall and check the lint trap. Unit was unplugged for about ten minutes. Didn't do a thing to the dryer or lint trap and it's worked fine ever since. Not sure if it's related or not but you've got nothing to lose by trying.
  • 489 Answers
You have a problem with the control board and it needs to be replaced.  Something to do with it's internal programming.
Posted on Apr 28, 2008
WHY IS MY LG GAS DRYER NOT ADVANCING TO COOL DOWN CYCLE?
If its a newer dryer, they have moisture sensors that determine if it should shut down early or stay on longer if needed. Let it run the extra time and see what happens. If it keeps doing it, then the sensor is defective.
Feb 21, 2016 | LG Dryers
Dryer stops at 6 minutes on sensor cycle
If you have chosen the manual mode and the dryer works well , then the fault can be with the sensor. need to check if there is false reading or if the control board has a issue.
Try to clean the unit and reset for a trial.
Oct 18, 2011 | LG DLE2512W Electric Dryer
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
Dryer on sensor dry - gets stuck on 6 minutes and does not finish
We have been having this same problem. I had tried adjusting everything that I could think of when putting a load of laundry in and got the exact same results as you. I would select the sensor dry and it would count down just like normal until it got to 6 minutes and then it would just run forever at 6 minutes.
My husband and I searched online all this afternoon and came across what seemed way to simple to work. We removed the lint filter, unscrewed the filter housing right inside the door of the dryer, and got to the sensors. We took a damp cloth and wiped them off very well to remove any and all buildup. We wiped everything down very well to remove any built up lint and/or dirt and put everything back in place as was before. We then unplugged the dryer for about a minute and then plugged back in. We put a load of already dry clothes into the dryer and started as usual with the sensor dry. It started out at the usual 41 minutes then skipped down almost immediately to 6 minutes and then a few minutes later I heard the most beautiful sound I have heard in a long time. The Beeper signalling that the timer had counted down to the end and was finished. It had worked. Thankfully. Hope this helps you also.
Feb 10, 2009 | LG DLE2512W Electric Dryer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Time skips from 18 minutes to 6 minutes on automatic mode
It is the moisture sensor system, it is not sensing the wet clothes. Open the door, inside you should see a part with 2 metal bars that is around 3 inches long, clean these bars with a mult purpose cleaner. Sometimes fabric softner sheets and detergent builds up on this so that the machine cannot sense the moisture. Hope this helps.
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
LG DLE2514 Electric Dryer Logo
281 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
