Question about Microsoft Windows XP Professional
Help cannot detect hard drive
Can you shed some light on me? Sometimes, my other computer (not this one as my family own four: one newly bought (I am using it), one with this problem, one three years old, and one... i don't know but we have four computers) cannot detect the hard drive. My father already fixed it, but I fear it would come back again. Please help me!
  • 1 more comment
  • Jan Mikhail Tiongson
    Jan Mikhail Tiongson Apr 03, 2008
    No, it's new. I mean in the POST I can't see any word of the hard drive.
    Jan Mikhail Tiongson Apr 04, 2008
    It's the hard disk that is not being detected. Anyway, thanks.
  • Josh Gahan
    Josh Gahan May 11, 2010
    is it still not detecting it ? otherwise i'd say your father solved this problem ?
    if he changed the physical hard drive and it does come back could be the IDE channels or The IDE controllers on the motherboard , and in that case if it really is that old you should buy a new pc
    Novelist:
    Champion:
  • 236 Answers
Probably cable problem only. rechk your cable the IDE and the power supply. maybe loose connected. the hardisk your a mentioning not detected is that additional disk or just only one?
Posted on Apr 04, 2008
  • Redentor Rivera Apr 04, 2008
    check your new drive jumper setting. if it is additional you have to make sure it is set to the right setting wether it is master or slave. if you set it slave then your original hrdisk must be slave. if both selected as master then you will not find the hard disk. if it is just one new hdisk attached then check your bios/cmos setting and change your hardisk type option to autodetect.
When trying to install a new operating system on Acer Aspire ICL50, the main drive is not detected. I have tried formatting with boot and nuke and have been given errors. I've tried installing arch linux,...
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this... Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good luck.
Jul 28, 2014 | Computers & Internet
Hi, I have a Maxtor 1000G external hard drive my computer responds to say it had detected new hardward but non can be found on the computer? I can I solve this?
That drive is not yet been formatted.you must format it first before you can use.
Follow the steps.
1. Right click My Computer then click manage.
2. Locate the newly installed Drive then click format then follow the default settings
3. Finished.
Hoope this will help.
Larrix
Jul 09, 2011 | Computers & Internet
The external hard drive isn't being read from the computer. Sometimes, the hardware will light up and sometimes it doesn't. The computer is not able to detect the hard drive. Please advise.
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 29, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I have a AL 1715 Monitor that takes forever (sometimes Hours) to appear . Power Light comes on but just flashes Green. Bought new power cord and video cable but still have the same problem. Dont have...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
May 22, 2011 | Computers & Internet
Hello my dell laptop's WD 500 BEVT stopped booting. a technician took it out and since then i bought usb connector trying to connect my newly housed wd with my other computers. although it will be...
you need to connect this using a sata cable and sata power lead to a spare sata port on your computer, t should then be recognised as a legitimate drive
Mar 25, 2011 | Western Digital Passport WDXML800UE...
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer...
try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Feb 28, 2017 | Maxtor OneTouch 4 Mini 120GB External USB...
My usb doesn't detected by any computers since I plug it to one computer. The red light does'nt appear anymore. My father bought it newly last week, I really wonder whats happening, I didn't even drop it...
USB what???? I assume a memory stick.
Can any PC ID the stick in "My computer" if not the stick is faulty assuming that NO PC's can ID it.
If you can see it in the above then double click on the drive letter for it and access files.
NB = Some memory sticks have a software disk to arrange security....ifyous has this disk then install it.
Jan 07, 2010 | Electronics - Others
I bought a external hard drive and want to backup my dvd's on it. What do I need in order to do this?
All you need is a good working DVD ROM and a 2.0 usb port.
Plug in your hard drive to the usb port.
It should install and be ready to use in a few minutes.
Insert your DVD's
Open My Computer and open your dvd disk (right click on the icon and choose open)
Open My Computer again but this time open your newly inserted hard drive (there will be an icon naming the drive)
Now, just use copy / paste from the dvd to the hard drive (you may have to create folders on the hdd to keep it organized)
Hope this helps.
Nov 02, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
Using sabrent 5-in-1
You can check 'Drive Management' via right-clicking 'My Computer' and clicking 'Manage'.
If you can see the drive in 'Drive Management', try changing the drive letter. Sometimes, newly added external hard drives end up having the same drive letter as an existing drive. This will cause 'My Computer' to not recognize the drive. Changing the drive letter can help.
Feb 17, 2009 | Sabrent SBT-FWPH (SBTFWPH) Serial Adapter
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
