Question about Samsung YP-U3 MP3 Player
My YP U3 don't turn on
Hi, I was listening my musics when the player turned off by himself and i can't turned it on again. I thought that was charged down, but when I putted it in USB nothing happens: none lights on, and the USB isn't crashed. It doesn't chage up, doesn't turn on and the PC doesn't see any device in USB.
Thanks
  • 7 more comments
  • joao_liborio May 09, 2008
    Hi, my mp3 player back to work by himself (by the same way it crashed). I only let it rest for some hours (about 8 hs) and then it charged up and works fine until now.
    Best regards.
  • chill18 May 23, 2008
    i'm experiencing the same thing, i'm very unsatisfied.
  • weisste May 29, 2008
    I had the same thing happen with my Yp-U3, it just stopped playing one day, thought it was dead but wouldn't accept a charge, then the next day it worked just fine! Now it won't turn off! It is as if my song is paused, but it still has the playing symbol on in the top left corner. The screen in on, on the song it stopped playing! Should I wait for the battery to run out? see what happens?
  • ashloz May 31, 2008
    got the exakt same problem!!!
    Just hope it's gonna work in a couple of hours...
    The text in the mp3 player is still "glowing".. but it keeps fading hour by hour..
    cant't turn it on, cant even connect to computer!
  • Anonymous Jul 18, 2008
    i hold the power button and don`t turn on.
  • Anonymous Dec 23, 2008
    i have the same freakin problem!!! bcuz my samsumng yp-u3 green is not working?!!! it charge perfect but dont turn on??? wtf?
  • h8ukbz Jan 24, 2009
    i'm listening then it stopped.
    i powered it on, then BOOOOM. it didn't work.
    i plugged it in on my laptop, still, didn't work.
    it gave me no signs of defects. just "surprise! i'm gonna die in 5 4 3 2 1."
  • anu15 Jan 27, 2009
    my samsung yp-u3 doesnt turn on. some one help to solve this
  • jim_elvisfan May 10, 2009
    I slided the hold button to unlock while accidently pressing the rec button,,thats when the player turned off and now it wont turn on...I herad than hold and rec button does sth to the system setting...so how do I turn on????
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Posted on Sep 12, 2008
I haved same problem and look what i do it...i open the case of mp3player i took the back with battery and i charge it a little to be able to start when i press on button, then i just close the case and plug it in usb port and voala, it's working and charging again...hope it will help others with this kind of problem
Before to do this it have next symptomes:
When i try to on it, it show me on screen low battery and after a while trying and trying this only blue lights get on and that's all
When i plug it in usb port it show me connecting... then it shutdown and again connecting...doing this all the time
Why he do it?because the battery was too low to start mp3 or to connect it to usb port
One advice...if you don't wanna buy new mp3player try to don't listen music until battery it's low or to don't force it when it's low(it's battery low? just plug it to usb to charge it and that's all...if you force it to start it you don't do nothing good and you woun't listen too long time music, you risk to over low the battery!)
Posted on Nov 26, 2009
Same thing here except the blue light on the end is lit & stays on. Only had the player 35 days.
Posted on May 09, 2008
I got the same problem with a usb sony mp3
i have it connected to my PC and it turns on some times and says battery low then i turns off lots of time
i hope it works in some hours :S T_T
Posted on Aug 14, 2008
Okee
Posted on Jul 24, 2008
I suggest you take the MP3 player and throw it away into
the dustbin, it works and will make you happy if you can buy another one; only $70... Quite good.
Posted on Jul 07, 2008
My mp3 have never worked, since i bought it, when i charge it, it just worms up, and no light appears, it is completly shut down, and my computer doesn't recognise it when i conect it by the USB.
Posted on Sep 10, 2008
5 Suggested Answers
  • 5 Answers
SOURCE: samsung YP-U3 MP3 PLAYER
Faulty unit, contact manufacture. possible firware update needed. You could try this your selve but would need the unit to switch on when connected to pc
Posted on Apr 14, 2008
SOURCE: My MP3 YP-U3 don´t power up
the battery might be dead. or u might have to take it apart and charge the battery by hand. ive done this before and it workd. i used a usb cord (5 Volts Max) wat ever u do do not charge the battery with anything over 5 volts. the battery inside the mp3 player is 3.7 volts, so be careful. It unplugs from the chip inside and the battery is easy to get out DO AT UR OWN RISK - PARTS ARE SMALL AND CAN BRAKE WHEN HANDLE CARELESSLY all u gotta do is find the seems on the sides and pull the player apart until it cracks open. then pull the connection tabs up for the usb and buttons from the chip, then by the hold button the chip will be guled to a ground, pull it apart and filp over the chip and u will see a lil clear plug with black (-) and red (+) wires on it, un plug it and set everything else aside, all u need is the battery. Now u need to find a old usb cord laying around and cut the end off that doesnt conect to the computer, splice the cord so that the wires are showing, cut them off EXCEPT FOR THE BLACK AND RED, now plug in the cord to a computer, or game console (ex. Xbox 360, Wii, PS2) then forcefuly slide the black wire onto the black (-) prong on the battery plug, same thing with the red one (+)
then let it set for 15 mins. now u have to conect everything back the way it was and snap the player back together and see if it will come on, if not you might have to take it back and get a new one if you have ur receat. i hope this works remember be very careful with the inside componets. Good Luck!
Posted on Jan 02, 2009
golu_fixya
  • 213 Answers
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
hope this is helpfull or if problem still please type in comments
regards
golu_fixya
Posted on May 06, 2009
webmaster21
  • 803 Answers
SOURCE: mp3 samsung yp-u3
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Posted on Oct 05, 2009
Samsung YP-U3 mp3 player display is DEAD..won't
Probably the display is off. Go to Settings and change 'Display Off' setting to 'Display On'. I have attached a link to a PCMag review of your player to help you.
Samsung YP U3
Dec 18, 2014 | Audio Players & Recorders
MY SAMSUNG DOESNT WORK AT ALL. WAS LISTENING TO MUSIC AND IT JUST SHUT DOWN!! DOESNT REACT,THE COMP DOESNT RECOGNIZE USB... PLS HELP
try keeping it turned off for a while then it will completely drain the battery. then charge it for 3-4 hours. it will be working then
Aug 21, 2009 | Samsung YP-U3 MP3 Player
Samsung yp-u3 will not play anything
the reset combo doesnt work, i have the same probelm.
but its hold and the two top buttons.
but it wont work
Feb 15, 2009 | Samsung YP-U3 MP3 Player
Cant turn on 2 brand new fully charged music on
you need to upgrade your usb port go on the samsung website it will tell u how
Dec 25, 2008 | Samsung YP-U3 MP3 Player
NEED HELP
Take out the USB from the MP3 Player. Connect it to your Computer. Go to "My Computer" and go to where it says "Portable Devices". Under where it says, "Samsung YP-U3". Double Click and Double Click "Samsung Flash Media". Double Click "Music". And put MP3 Songs, to the folder. Now it's ready to listen to it.
Thank You for Using FixYa!
Good Luck with your MP3 Player!
Oct 29, 2008 | Samsung YP-U3 MP3 Player
Driver for Samsung YP-U3 - Windows ME
u don`t need a driver ... the samsung yp-u3 is not a regular mass storage drive u must open it with this program http://www.samsung.com/sg/support/download/supportDown.do?group=mp3audiovideo&type=mp3player&subtype=mp3player&model_nm=YP-U3ZB&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=03040200&acc_ia_fl=&disp_nm=YP-U3 download from here
May 05, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 PLAYER
Apr 14, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 won't charge anymore
it is possible that either your cable is bad or the battery is dead. but first try hitting the reset button on the back-(it is a tiny hole on the back, towards the bottom) - use a small paperclip
Mar 13, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Logo
3,884 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
