Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Whining high-pitched noise when RCA D52W20 is on
I am trying to find out what the problem may be and how can I get it repaired
  • 149 Answers
Its a coil in power/deflection board and need to be experienced in order to fix this
Posted on Apr 03, 2008
SOURCE:
Making high pitch whine or squeeling
Check the color wheel and any fans running on the unit. The color wheels make a high pitch whin right before they quit as well as the cooling fans.
Jul 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
High pitched noise
there may be abreak on the av board . is it doing on cable,dvd another source the front panel jacks sometimes develops breaks sound like you may need a tech look at it
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 20
sounds like the Power Transformer to me,  usually accompanied by a high pitch (almost inaudiable whine) and  sparks arcing.
This needs a professional repair..
Oct 11, 2007 | RCA F27252GY 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
