I CANNOT TURN MY COMPUTER ON . THE BIOS SYSTEM DISABLES MY UNIT. HOW DO I BY PASS BIOS SETTING.ASPIRE 3000 SERIES
    Sergeant:
  • 349 Answers
You can't bypass the bios setting,if you mean reset the bios, there may be a jumper to clear the cmos (bios) just change the jumper to clear, then put it back in its original place ,or take the battery out of the motherboard (very) gently for about 10 minutes then replace it ,then turn on the pc
good luck, let me know how it goes
Terry
Posted on Apr 03, 2008
  • terry Apr 03, 2008
    jumper will also be on the motherboard
How can i getthe bios for may acer aspire one series model zg5
Things You'll Need:
  • Acer Aspire laptop
  1. 1
    Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
  2. 2
    Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
  3. 3
    Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
  4. 4
    Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
Read more: How to Access an Acer Aspire BIOS ' eHow.com http://www.ehow.com/how_5809235_access-acer-aspire-bios.html#ixzz1E2WkwLWf
Feb 15, 2011 | Acer Aspire One PC Notebook
I have an acer laptop 5735-4061. I was using this morning just fine. I got up to go do something and then I came back and there was a black screen with a blue bar in the middle of the screen. I says...
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Feb 04, 2011 | Acer Aspire 5735 Notebook
Hello.i have a aser laptop (model:aserspire 5738z-432g)that forgot bios pass.i now want that remove this pass.may be help me?thanks
you can clear coms but if your are sure you can dismantel your laptop carefully then you can remove the coms battery and turn on once and fix it back that will reset your coms setting.
Nov 27, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 3000 Series Laptop Splash screen does not appear at startup when pressing F2 on the post page. Therefore unable to acces bios. Has e-manager but cannot access bios through it either. Welcome all...
It sounds like the Acer logo has been turned off in the bios settings. As soon as you hit the power button, start tapping the F2 key until you see the test appear "entering setup". Once you are in the BIOS, look for the Logo settings as far as being visible during Boot up. I've seen this setting on other systems so I am thinking the Acer should be similiar.
Jun 19, 2010 | Acer Aspire 3000 Notebook
Acer Aspire 3000 problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} No. JUST RESET YOUR BIOS SETTING TO DEFAULT. Your HD is OK
Sep 11, 2008 | Acer Aspire 3000 Notebook
ACER ASPIRE 3000/5000 SERIES LAPTOP
Log on to your computer with safe mode
Steps
1. Start your computer
2. As soon as you see the first black screen when the computer starts , keep on pressing F8
You will see advanced options menu
Select " Safe mode with net working"
Now your computer will give you an option to log in with the administrator username
You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
Thanks and dont forget to rate!!!!!!!!
Jun 04, 2008 | Acer Aspire 3000 Notebook
My Acer Aspire 3000 harddrive is full and my computer turn off and the on
What you need is a Window XP installer CD which have the SATA driver. Most of the older Window XP CD before 2008 does not support computer with SATA harddisk.
Or
If your BIOS setting permit, change the Harddrive setting eg from IDE to SATA and ICH setting.
May 10, 2008 | Acer Aspire 3000 Notebook
Big problems
start the system hit delete or F2 to enter setup load system defaults then exit saving changes.
if it didnt work
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 16, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
