Question about Mitsubishi WS-55311 55" Rear Projection Television
Mitsubishi WS-55311 answer you gave me.
Sorry I had my friend doing all the computer work while I was behind the TV.
What he ment to say was that when we use component there's a picture, but it's only using the blue bulb. The rest seem to be shining a bit but not putting off any images. Composite on the other hand works perfectly, full color, aligned and everything. I think the input board may have been messed up when we moved the TV, I've taken ti out once and will probably just replace it, there's really nothing else that could have been disturbed as far as I know; unless I can't see a connection from the back of the TV.
Thanks again
~Steve
StephenMurawski@gmail.com
  • 927 Answers
Before you replace a board, please double check or use different cables, make sure the cables are in the proper out/inputs, rgb to rgb. Try 'comp' 2. Composite vs component uses two different paths to produce a picture. Also, after taking tv's back off ensure that all boards are seated properly, since this happened after movement. CAUTION: make sure the unit is poweless, unplug tv. Let me know. Good luck....
Posted on Apr 04, 2008
  • MICHAEL MULLINS Jul 21, 2008
    Good Day,
    Steve;
    Did you get the TV repaired? Let know if you need an more advice, I'll try to help.
    Thanks,
    big IRISH.
Mitsubishi WS-55311 55 In. Rear Projection Television will power on but won't stay on
When it shuts down have you tried accessing the self diagnosis feature to retreve the error code?If so whats the blink code your getting?
Feb 10, 2013 | Mitsubishi WS-55311 55" Rear Projection...
How to unlock my keys on my mitsubishi tv model #ws-55311
Here is a link to the owner manual for this model--keyboard lock release is on page 32---might want to down load a copy of the manual as it is free.
http://www.scribd.com/doc/35942919/Mitsubishi-Owners-Guide-TV-vs-50111-Vs-60111-WT-42311-WS-48311-WS-55311
SD TECH
Jun 02, 2012 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi ws 55311 power not working
Try website like Tvrepairworld.com to buy a refurbish DM power board for the replacement or parts.U know soldering?Buy capacitors for repalcement.
May 14, 2010 | Mitsubishi WS-55311 55" Rear Projection...
My WS-55311 in pluged in and no power at all - no lights not anything -- what could be wrong
looks like u have a bad switch at the control panel . what u can do is take the fron speakers grill off and unpluge the front panel and turn u tv on with the remote control it should work
Apr 19, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Model 55311 Can you pick up digital tv without converter box?
I am thinking that you have a Mitsubishi WS-55311. If this is the case, you will need a converter box to receive digital television signals.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
Sep 20, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi ws 55311 format issues
Apparently I did not have the correct remote to go with this television. The remote I had was a Mitsubishi, but I was able to obtain one that had the 'format' button.
Jun 21, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi tv ws-55311
Mine did the same thing. It was too much money to invest in old technology. I chucked that baby to the curb and got a 42" LCD. LOVE IT!!
Apr 25, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WS-55311
check the error codes to see what's wrong, do this by search threads here or at ctechnicians.com
Dec 31, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
