do you need instruction as t ohow to run self clen cycle??? or just general how do i clean my oven surfaces???.just need the model number adn ill look up the schematic
Same Problem
Feb 02, 2009
-   cleaning smooth tops? burnt on food dark and won,t wipe off
-   Guest
Use Glass cook top cleaner by Weiman. For stubborn burnt on food use a scraper or razor blade and hold it at and angle almost parallel with the top of the stove top and scrape off gunk.
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot,...
(More)
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot, with no overhead hood. (also no overhead cupboards) i am looking at the frigidare PLCS389EC. Is this a good choice?
I just had a new oven element replaced by sears and now I get f10 error code. Did he forget to check...
(More)
I just had a new oven element replaced by sears and now I get f10 error code. Did he forget to check the temperature control?
