Question about Insignia IS-LCDTV32 32 in. Television
Picture problem I HAVE A THIN LIGHT BLACK VERTICAL LINE ON THE RIGHT 1/4 OF THE PICTURE. HAD A SIMULAR PROBLEM WITH MY SONY SXRD AND PROBLEM WAS TRACED TO SOMETHING CALLED VIDEO BLOCK. SONY FIXED IT EVEN THO SET WAS WELL OUT OF WARRENTY (due to a law suit) COULD THAT BE THE PROBLEM HERE? Thanks Kerry Richards krichards@consolidated.net
  • 109 Answers
Yes, that;s it, digital board issue.
Posted on Apr 03, 2008
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
Mar 20, 2010 | Sony KDS-70R2000 70" SXRD TV
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Insignia IS-LCDTV32 32 in. Television Logo
59 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
