Question about Maxtor OneTouch II external hard drive 500GB 7,200 RPM - FireWire & USB (E04W500)
My One touch drive just stopped working.
It doesn't show up on Disk Utility. Help!
  • sawatzki1 Sep 12, 2008
    I had my computer wiped clean and backed up my files to my Maxtor II so i could recover them after I put my programs back on. Now my computer does not recognize that my maxtor is pluged in, so i can't access any of my saved files on my maxtor unit.
  • Anonymous Jan 20, 2009
    i didnt appear on mac desktop it appear on my computer on windows but u cannot view or open it, when i repair it on disk utility on this error appear:
    unable to read FAT (input/ouput error)
    Error: The undelying task reported failure on exit
    1 non HFS checked
    1 volume could not be repaired because of an error
    what should i do
    Problem Solver:
  • 4 Answers
It seems That this drive has not been recognized by your computer.
Try this; because the drive is a "removable device" disconnect switch off reconnect and switch on.This will send a signal to your computer that a new device has been Connected and perhaps you may need to follow the install wizard instructions. you may have to do this for a number of occations but your computer will soon adopt your new external device as a valuable family member.
I hope this will solve your problem.
Good luck
Goffa
Posted on Nov 30, 2008
I bought a new toshiba canvio 3.0/2.0 plus (black) plug it in my macbook but it doesn't show on my desktop as well as on my disk utility, i plug it in another older macbook it shows on the deskto
the disk configuration in your laptop is not complete
  1. Select the drive device in the list of devices, which is the item above any storage volumes on the drive, and which may show the manufacturer name, media size, and so on.
  2. Choose the "Partition" tab that appears.
  3. Select "1 Partition" from the drop-down menu (or more, if you have specific need for more than one volume). When you select a new partition layout from the drop-down menu, each new partition will be formatted to Mac OS Extended (Journaled) by default, but be sure to double-check this by selecting each in the partition diagram and then choosing the format for it.
  4. Click the Options button and ensure "GUID" is selected as the partition scheme.
  5. Click Apply to save the changes.
Sep 21, 2017 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
Tip
Using Windows Disk Management Utility to Manage Internal and External Disks
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a “Drive” and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”)
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter “C”.) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters “F” or “G”. In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
on Jan 29, 2010 | Computers & Internet
My power mac G4 is not opening safemode as well as it is not boot from CD
Two possible things are wrong either your hard drive has gone or your system has corrupted. Put your instal or system disk in start it up holding down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay run the disk utility check drive and then run the repair permissions. Then try restarting, if it works then you are back up and running again. If the drive shows up and you restart and the same thing shows up with the grey screen, you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents your will MUST use the preserve users instal.
If your hard drive does not show up the hard drive is probably a gonner and you will have to purchase a new hard drive and instal a fresh system.
Hope this helps
Nov 17, 2011 | Apple PowerBook G4 Mac Notebook
I bought an Imation Apollo II (320GB) and had it formatted for my macbook in the store I bought it. It has worked fine up until 2 days ago. Now, when plugged in, it says only 'the disk you inserted was...
Hello barry_carrot,
I work for Imation and we would advise you to try the following option:
restart to your Macbook without the external drive attached.
Open your Disk Utility (in your Applications/Utilites folder).
Plug in your hard drive.
If the drive shows up in the list in the Disk Utility First Aid window, click on the drive, and then click on Repair Disk. If the process repairs anything, run the same Repair Disk a second time to see that it runs with no problems found. If some other error comes up, or it won't repair a problem found, then I would recommend moving this drive to a PC, and trying a repair tool through Windows.
Note: if you see the "repair" option grayed out, Going back to Disk Utility - (you won't be able to select Verify/Repair Disk Permissions), but Verify or Repair Disk should be available if you click on the device (the entry showing the manufacturer's info for your external drive).
If that doesn't help you, please contact the Imation product support department at the phone number 1-800-351-8186 option 2.
Jul 20, 2011 | Computers & Internet
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
I have an external hard drive made by Gigaware. When plugging it in, the computer recognizes it as mass storage device but will not show up in My Computer. The external drive is on and spinning. Any...
If you have not used the external hard drive before, you will have to go into your drive management and initialize your drive and possibly format it. The fact that your computer recognizes it is a good sign. It means that the external drive is working properly and the computer recognizes that the external drive is there. I have an short paper I have written describing how to use the drive management utility in windows. It is too long to post here. I can either post part of it or you can give me your email and I will send it as a MS word attachment so you can have the entire paper.
I hope you find this helpful Brian
Here is the part I can post here:
Using Disk Management Utility
A menu will open
Chose "Manage"
Dec 25, 2010 | Computers & Internet
My western digital dosent get detected, whenever i connect the device a new hardware found sound comes and nothing comes in my computer, i tried restarting nd olso tried to connect the device on other...
sometimes drives need to be initiallized when they are connected I will give you instructions to use the Manage Feature of windows to manage your drives. The instructions are as below:
If you cannot see the drive using the disk management utility, then you need to check to be sure the drive is not malfunctioning and also check your connection cable to be sure it is not the problem.
I hope this is helpful!!
Brian
#2- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Dec 23, 2010 | Western Digital 320GB MyBook External USB...
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Hard drive doesn't show being hooked up. Won't work
The firewire chip may have bit the dust. Open finder, and go to applications, then utilities. Open Disk Utility and see if you can see the drive there. If you can, verify and repair the drive using disk utility and see if the problem goes away.
Mar 17, 2009 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
