Question about Philips Magnavox 20MS233S 20" TV
How to enable caption without a remote control
That's all folks, my brother broke the remote and I want to enable the caption using the bottoms
  • Charls Apr 03, 2008
    Thanks but the model seems to be older as the caption option doesn't appear, I will have to buy a new remote for it
Cant you just hit the menu button on the bottom of the tv and go through it and find captions and then hit enable?
Posted on Apr 03, 2008
How to turn off sub titles using urc7110 remote
You probably have closed captioning (not subtitles) enabled. Closed captioning is enabled/disabled as part of initial set up.
Jul 11, 2016 | One For All Televison & Video
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How do I turn off voice narration on my receiver?
If you mean Closed Captioning it can be disabled by hitting MENU, Preferences, Closed Caption. Make sure your TV doesn't have Closed Caption enabled by using your TV remote.
Feb 19, 2015 | DISH Network ViP722 DTV Receiver /...
Hdmi cable closed caption
Are you using the cable box settings (or remote) or your TV's remote to select the closed captions. When you use the HDMI cable, you need to enable the captioning on the set top box. The TV can only interpret the CC if the signal goes through the tuner (coaxial cable input). It's a matter of how they built the hardware; the cc interpreter is part of the tuner.
Which cable provider do you have? I know with some providers, there isn't a direct CC button on the remote. With them you need to go through the Settings menu to enable the closed captions. If you add a comment with your provider, I may be able to help you enable the CC if there isn't a CC button on the cable remote.
I hope this helps.
Dec 11, 2013 | Emerson Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
Turning on closed captioning
If you have a cable box or a satellite receiver you will set up closed captioning on it. For most cable boxes you have to turn off the power and immediately press the menu button on the front or them. Then the hidden menu appears if you've pressed the menu button on the cable box itself and not on its remote soon enough. Then you scroll down to closed captioning and enable it. Turn the cable box back on to view your channels with closed captioning.
If you have satellite tv you can press one of the colored buttons on the remote to get to a menu that will allow you to enable closed captioning.
Dec 30, 2010 | Toshiba 40G300U TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
OBTAIN CLOSED CAPTIONS WITH UNIVERSAL REMOTE
can;t with universal need to do it manuelly in main menu
May 05, 2010 | Prima C2012 TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Philips Magnavox 20MS233S 20" TV Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
