Question about Baby Gear
2003 Mazda pick up clutch
Clutch feels out of adjustment may have air in line. How do I adjust or bleed the line. Pedal goes almost to the floor before engaging to change gears.Vehicle has 65,000 miles.It is a B2300 2.3liter, 16 valve 4 cylinder,hydraulic clutch.
    Problem Solver:
  • 12 Answers
Look for the small master cylinder resiviour beside the larger one for the brakes. Take the cap off and check the level, it is probably very low fill it with the type of fluid labled on the cap. The clutch is self bleeding these days, pump the pedle fast for like 50 strokes or whatever it takes to get a firm pedle. Check your fluid level again, you will probably need to add more. now look under the truck for a leak, especially dripping out from between the bell housing and the engine.
Posted on Jul 05, 2014
    Genius:
  • 1,665 Answers
Check first fluid level to be in the marked lines. Refill if necesary pushing clutch pedal repeatedly.
Posted on Apr 03, 2008
Brake pedal goes to floor
for the pedal to go to the floor there is still air in the brake system. Start again starting from the longest line bleeding each in turn to the shortest line . make sure you have adjusted up the rear brakes before bleeding as every time you press on the pedal the shoes expand right out and when you take your foot off the pedal the shoes go all the way back in. adjust them manually and do not rely on the self adjuster as it only adjusts on wheel movement
Jul 15, 2013 | 2002 Ford Explorer Sport Trac
Clutch pedal goes to floor and half works on my b2200 1987 mazda pick-up
If the clutch is hydraulic operated, you need to bleed the clutch at the slave cylinder, down on the transmission housing. Bleed it just like you bleed brakes of air in the line-open bleeder valve, someone pushes clutch pedal slowly to floor, close valve, and repeat until fluid comes out valve in a steady stream. Make sure the clutch reservoir is full before starting. It uses regular brake fluid.
If not hydraulic, it would be cable operated. Adjust the cable until clutch pedal is right.
Dec 29, 2012 | Cars & Trucks
Had my clutch changed 4mths ago, everything was fine... pedal for clutch sometimes feels a bit sticky to floor, goes into gear ok and clutch seems fine, could this be air in in the pipe?
POSSIBLE AIR IN HYDRAUIC LINE BLEED THE VALVE KEEPING AN EYE ON FLUID IT HAS A VERY SMALL RESEVOIR. OR CHECK PEDAL RETURN SPRING MIGHT HAVE LOST TENSION.
Jan 27, 2011 | 2001 Ford Focus
Shifter works when car is off, start car and then shifter won't go in gear. if i start vehicle in first with clutch pedal to floor, car starts going forward. mazda miata mx-5 just put new slave cylinder in...
The one item I would suspect is the through-out-bearing not completely disengaging the pressure plate from the fly wheel. If the vehicle is in neutral and you slowly depress the clutch and release it do hear a singing or whining sound? Since you cannot adjust the clutch any more the through-out-bearing is the component which moves the pressure plate from the fly wheel to stop the power from the engine to the transmission. It is difficult to shift when the engine is on because the fly wheel is still engaged and powering your transmission.
Aug 06, 2010 | 1997 Mazda MX-5 Miata
1987 Maxima-5 speed is difficult to grt in to gear--How to adjust clutch and check clutch hydraulic fluid?
TO ADJUST PEDAL HEIGHT ADJUST WITH A STOPPER LIMITING THE UPWARD TRAVEL OF THE PEDAL.PEDAL FREE PLAY IS ADJUSTED AT THE MASTERCYLINDER PUSH ROD.IF PUSH ROD IS NON ADJUSTABLE FREE PLAY IS ADJUSTED BY PLACING SHIMS BETWEEN THE MASTERCYLINDER AND THE FIREWALL.ON A FEW MODELS PEDAL FREE PLAY CAN ALSO BE ADJUSTED AT THE OPERATING SLAVE CYLINDER PUSHROD.PUSHRODS ARE AVAILABLE IN THREE LENGTHS FOR THE 310.PEDAL HEIGHT ABOVE FLOOR IS 6.73 - 7.13 INCH PEDAL FREE PLAY IS 0.04 - 0.12 INCH.YOU HAVE CLUTCH FLUID LONG AS YOU SEE BRAKE FLUID IN MASTERCYLINDER.IF MASTERCYLINDER LOW YOU HAVE TO BLEED THE THE CLUTCH MASTERCYLINDER BY LOCATING BLEED SCREW ON SLAVE CYLINDER. REMOVE THE BLEED SCREW DUST CAP.ATTACH A CLEAR TUBE TO THE BLEED SCREW.PUT OTHER END OF CLEAR TUBE IN A CLEAN CONTAINER OF BRAKE FLUID.FILL THE MASTERCYLINDER WITH BRAKE FLUID.OPEN BLEED SCREW 3/4 A TURN.DEPRESS CLUTCH PEDAL QUICKLY.HOLD IT DOWN.HAVE A HELPER TIGHTEN THE BLEED SCREW.ALLOW PEDAL TO RETURN SLOWLY.BLEEDER SCREW TORQUE IS 5 - 6 FT LBS.IF YOU SEE AIR BUBBLES CLEAR BLEED TUBE.REPEAT THE BLEED PROCESS UNTIL YOU SEE NO AIR BUBBLES.DONT LET CLUTCH MASTERCYLINDER GO DRY WHILE BLEEDING.IF SO YOU GOT START BLEEDING PROCESS ALL OVER.HOPE THIS HELP.
Aug 05, 2010 | 1987 Nissan Maxima
Clutch wont work
Check and make sure you have fluid in the clutch master cylinder. If it is low fill and check for leaks. Repair leaks as needed and bleed system. If fluid was full check adjustment and bleed system, if there is air in the system pedal will go to the floor.
Oct 02, 2009 | 1991 Mitsubishi Eclipse
New clutch doesn't feel right. Replaced clutch, master cyl and slave cyl and hydraulic line. Bled the line. Its still a little hard to get into gear. The clutch pedal engages the clutch very extremely...
this happens for a while untill everything settles,but the are adjustable slave cylinder rods,even after bleeding the system takes a while to work properly.
Sep 09, 2009 | 1993 Chevrolet C2500
Grinding when engaging into gear when warmed up.
ok every time you open the clutch resevoir you have to bleed the slave ..next hold down the clutch to the floor open the bleeder screw 10 mm bolt and then close it and pick the pedal up off the floor if your clutch is not right the pressure plate is failing most likely on mitstu stuff ...bleed first ..
May 08, 2009 | 1990 Eagle Talon
Clutch pedal stays on floor
the problem is that either the master or slave cylinder for the hydraulic clutch have failed, it is always recommended that they both replaced together, u can bleed the clutch but the problem will occur again.
May 07, 2009 | 1994 Mazda MX-6
Need to make a clutch adjustment on 1991 Mazda B220 pickup
Check the fluid, check for leaks, if there is replace the cylinder or hose and bleed the lines of any air. There a two cylinders, the master cylinder(on the fire wall not far from the brake cylinder) and the slave cylinder(on the gearbox) i think this maybe your problem.
Nov 08, 2008 | 1988 Mazda B2200
Baby Gear Logo
123 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
