Question about AMD Duron , 750 MHz Processor
How to upgrade
I have my amd duron 750mhz processor iwant to upgrade it
  • 2 more comments
  • mykel023 Apr 03, 2008
    the model number of my motherboard is ak33 thx for the help cant use most of my programs due to some requirements such as upgrading my processor thanks
    thanks for the solution it could be a great help by the way is it safe for my motherboard?thank you very much
  • mykel023 Apr 09, 2008
    i bought a new motherboard with a processor socket number of PGA370 kindly help me ho to find a compatible processor thanks a lot God speed
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    you need to post the make and model number of your motherboard.
  • 236 Answers
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Posted on Apr 03, 2008
  • 2 more comments
  • Dave MacPhee
    Dave MacPhee Apr 03, 2008
    if you have the money, I would recommend upgrading your motherboard to a AM2 socket, and then you can upgrade your processor and ram cheaper..
    A good AM2 motherboard will run around $80-$220 CAN
  • Dave MacPhee
    Dave MacPhee Apr 04, 2008
    yes, it will be safe for your motherboard.. If you are really hesitant, the AMD Athlon (without the XP) are the most compatible. The only thing that you may need to do it buy a better power supply, and make sure you have plenty of fans. Also, make sure the CPU that you buy comes with a heatsink made for it (most will have one included in the box)...
    That is why I suggested a new motherboard, as you will find more compatible and readily available CPU's for the newer mobo's.
  • Dave MacPhee
    Dave MacPhee Apr 09, 2008
    Should have gone for a motherboard with AM2 or pentium equivilant. You cannot use dual-core in that motherboard, so you are limited to a MAX Pentium III...
    This is probably the highest you can use:
    Family Intel Pentium III
    Part number RK80530PZ017256
    RK80530PZ017256 s-specs QLL1 SL64W SL6HR
    RK80530PZ01725E s-spec SL64W
    Frequency (MHz) 1400
    Bus speed (MHz) ? 133
    Clock multiplier ? 10.5
    Package 370-pin Flip-Chip Pin Grid Array with heatspreader (FC-PGA2)
    1.95" x 1.95" (4.95 cm x 4.95 cm)
    Socket Socket 370
    Architecture / Microarchitecture
    Processor core Tualatin
    Manufacturing process 0.13 micron
    Data width 32 bit
    Floating Point Unit Integrated
    Level 1 cache size ? 16 KB instruction cache
    16 KB data cache
    Level 2 cache size ? Full-speed on-die 8-way set associative 256 KB cache
    Multiprocessing Uni-processor
    Features MMX technology
    SSE instructions
    You may be able to find one of these more easily:
    Intel Pentium III 1GHz 133MHz 256K FCPGA CPU
    Unfotunately, Pentium 3 is pretty much phased out.. Even the Pentium 4's are going out the window...
    Any way you can change the motherboard for another one? (you will find cheaper chips as well for a newer motherboard)
  • Dave MacPhee
    I think you were better off with the older motherboard as it uses AMD and has better compatibility...
    The motherboard you just bought is pretty much out-dated...
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Can i upgrade my amd duron 850 mhz to 1.4ghz?
yes, depending what motherboard you have. almost all of them will support 1.4 ghz
Jan 01, 2011 | AMD Duron , 850 MHz Processor
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
Amd duron 1.34ghz processor
Yes, you can upgrade to Amd Athlon X2 64 bit but you may need to change the motherboard also.
Sep 25, 2008 | AMD Computers & Internet
CPU upgrade
Your motherboard has a good support for various Processors. If you want to go for the latest then you can go for Palamino core Athlon 4.Its compatible all the KV7 series boards but all you have to check is "Till WHAT clock speed can your board support?" .
Regards,
Sai.
Jul 10, 2008 | AMD Duron , 700 MHz Processor
Upgrading processor to Duron 1.4GHz
well older mother board cant handle a higher CPU processor, you have to make sure you have ALL the jumper properly set for the CPU, also the memory on the motherboard should be for that motherboard. try not to OC the motherboard as it will fry it.
Also check the motherboard for any Blown capacitor. for the MB to scream bloody murder something is definately wrong.
you could check the website of asus and look under ARCHIVE or DISCONTINUED motherboard. to find drivers and manuals for the motherboard you have unless you have them
also make sure the motherboard can actully take a higher processor.
Thermal grease is always good its help alot, just dont over do the grease applications. as ive seen pasta made out of thermal grease cpu's
Good luck
Jun 04, 2008 | ASUS VIA KT133A Chipset A7V133-C...
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
amd 3200 + anthlon ok with fsb 266 mhz soket a
Jan 10, 2008 | ASUS A7S333 Motherboard
K7VT2 with a AMD Duron 1.30 GHz CPU.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Nov 13, 2007 | Asrock K7VT2 Motherboard
AMD Duron , 750 MHz Processor Logo
616 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
