Question about Canon PIXMA iP6700D InkJet Photo Printer
Error U071 how do i solve about this error {more than one ink tank of the following color is installed}
  • 2 more comments
  • gin_e Apr 12, 2008
    Me too!  The ink tanks are correct, I don't know how many times I've taken them out and put them back in and power cycled the printer, and still it insists there is a problem! This is driving me crazy.  I cannot print!
  • Anonymous Apr 28, 2008
    Ich habe schon oft den Tank ausgewechselt, immer schreibt er Es sind mehrere Tintenbehälter der folgenden Farbe eingesetzt.
    Email: [email protected]
  • rahlaw May 15, 2008
    I keep getting the same message that more than one tank of ink is installed then switches to "does not recognize one tank of ink" what's the deal with these printers? How do you fix this???? It won't print anything.
  • Anonymous Mar 10, 2009
    Printer tells me to check ink, and that more than one color is un use at the same time.  It thinks that my yellow is a magenta...  which it most certainly is not!  WTF
  • 3 Answers
I think I have come up with a solution!
When the error happens:
Open the cover and re-seat the cartridge.
Tilt the whole printer forward about 30 degrees or more
Close the cover.
This has worked for me multiple times now. I think there is a small sensor behind the contact chip that detects ink levels and when my printer is flat the level of ink is lower than the sensor, when I tilt the printer the error vanishes because the ink covers the sensor. Though I am not sure why the software in the printer determines that there are duplicate cartridges instead of just a low ink warning.
If you still can't get it try taking a standard pencil eraser and gently rub it over the contacts to clean off any oxidation, also do this to the prongs that contact the chip that are inside the cartridge carrier, They bend easily so do it very lightly.
Posted on Jun 28, 2008
I can't fix ti too.
BUT... I did come up with a temporary solution.
1) Turn printer off.
2) Unplug USB cord.
3) Turn printer on.
4) Then plug USB cord.
It "should" work again.
Posted on May 07, 2008
4 Suggested Answers
SOURCE:
  • 421 Answers
SOURCE: error U071
Make sure that the inks are not re-manuafactured ones with chips taken off genuine canon inks. It is possible that the wrong chips could be fitted to the wrong colours.
Posted on Dec 07, 2008
  • 81 Answers
SOURCE: check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Posted on Dec 16, 2008
  • 73 Answers
SOURCE: error code U071 , more than one ink tank of te
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Posted on Nov 28, 2009
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Won't let me print and it says U071
That error is from a defective ink cartridge, if all are installed correctly. Most often I've found the 5BK cartridge to be defective. If the store won't exchange it you might call Canon at 1-800 OK canon
Jun 23, 2009 | Canon MP830 All-In-One Printer
I have error U071. I have been refilling the
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Feb 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Check ink U071 cyan
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error U071
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error U140 & U071 for Cannon pixma mp800
Thanks for checking back my printer problem. Solved the problem--purchased a new printer.My big problem now is repairs on my Mitsubishi WD 52725. I do not think I will buy a new one of those.I will purchase your help package for help with that. Please advise.
Cosie
Nov 26, 2008 | Canon Pixma MP800 All-In-One InkJet...
Printing Cartridge error
I've seen this problem before and it turned out to be a faulty chip on the cartridge as opposed to a problem with the printer. Canon should replace the cartridge free of charge if this happens.
Nov 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Canon PIXMA  iP6700D InkJet Photo Printer Logo
525 people viewed this question
Clive
Clive
old marine
old marine
Ekse
