Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore portable compact topload washer model 110 49722992--won't spin!!
All cycles work fine on the washer except for the spin cycle.  i can hear the motor running and for some reason the tub just seems to be locked.  it looks and sounds like it's trying to begin the spin but is being stopped.  please help.  thanks in advance.
  • murphy4 Apr 03, 2008
    thanks for the fast response. i didn't realize i was writing in the forum specifically for this model washer. my washer is very similar but is model #110 49722992.
    i think maybe mine is an older model. is there somewhere i can get a diagram to show me where the coupling goes?
    thanks again for your help.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Posted on Apr 03, 2008
Compact Kenmore top loadwasher does not spin
Clutch is failed. replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Dec 11, 2008 | Washing Machines
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
897 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
