Question about Kitchen Ranges
Water spilled in between the glass window. How do I open it up to clean inside of the glass window?
  • dd37 Aug 06, 2008
    how do i clean between glass on oven door...customer service told me to take door apart...what?!
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Make and model of unit please
Posted on Apr 03, 2008
The sove oven doar had a spill the spill went through glass and now in between the glass and i cannot get to it to clean.HOW CAN I GET THIS GLASS TO CLEAN I DONT NO HOW TO OPEN THE DOAR
The glass in oven doors is not designed to be removed and cleaned. Although theoretically possible, it is not practical to do so.
Nov 15, 2013 | Kitchen Ranges
Tip
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to...
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to about 1 foot, 30cm long making sure there are no holes in the toe or elsewhere, put a 1/4 cup or so of tobacco into the sock, tie a knot so the tobacco stays put. Then open the bonnet of the car, find the windshield wiper water tank, drop the end of the sock into the solution or plain water, make sure the upper end of the sock is securely fastened to something outside the tank so you won't loose the bag you created and you'll be amazed at how clean the windscreen will be next time you use the wipers after squirting the windshield as usual.
An alternative would be to boil the sock in water like tea, but don't drink it! after 10 minutes of boiling, let it cool, squeeze the bag so all the "tobacco tea" goes into the pot. When cooled, pour it into your windscreen water tank. As you wash your windscreen with the wipers going the squirted liquid will clean the glass and make rain water sheet off rather than leave droplets. You can actually drive the car safely because you can see as if no rain was falling.
If your wipers stop working all together and you can't see to drive, take a sock, as the one I described above, get it wet and wipe the windscreen with it. The rain will then sheet off the glass as if there was no rain at all. no drops can form. The tobacco breaks the surface tension. Want proof? Take a glass of water, fill it to the top just short of spilling over. You'll notice the water actually rises above the edge drop one grain of tobacco or black pepper and the glass will immediately spill the water out of the top of the glass. I keep such a bag in a plastic bag under my seat. You never know when you might need it. You can use it many times before needing change the tobacco.
If you just want some cheap glass cleaner, mix a 50% solution of white vinegar and pour it in your window wiper water tank. It will keep your windscreen nice and clean; also streak free.
on Jun 14, 2010 | Kitchen Appliances - Others
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Spills have run down inside the oven door and stained the glass of the window (on the inside). Can I easily take the door apart to clean it? There are two screws on the inside of the door...can I unscrew...
experimenting is always easy if dont care about the repercussion ,it will be easy to remove it but not easy to assemble it back you can clean it by keep it open and you should use some catalytic solution for it
Feb 25, 2010 | Kitchen Ranges
The inside of my washing machine smells
Regular cleaning maintenance is required to prevent odor build up inside the machine. The LG WM2688HWM has a TUB CLEAN feature, a special cycle for the cleaning of the inside of the washer. This cycle uses a high water level with higher spin speed.
  1. Remove any clothing or items from the washer and close the door.
  2. Open the dispenser drawer and add liquid chlorine bleach ONLY to the bleach compartment.
  3. Close the dispenser drawer slowly to prevent the bleach from spilling.
  4. Turn on the machine then press the EXTRA RINSE button for 3 seconds.
  5. Press the START/PAUSE button to start.
  6. Leave the door open to dry the washer door opening, door seal and door glass after the cycle is complete.
Dec 02, 2009 | LG WM2688HWM TROMM SteamWasher
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Water stain inside of screen glass
Yes, you can check with ctechnicians.com for instructions on disassembling.
Dec 23, 2007 | Hitachi 60EX01B 60" Rear Projection...
Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a job...Catriver..post back.
Nov 26, 2006 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
