Question about iLO (2 GB) MP3 Player
Write- protected my memory card form my phone won't allow me to add more music to it because it"write-protected" and that i need to remove that to be able to load more music. but i can't find where to do that!
  • 8,596 Answers
Right click device, go to properties, uncheck Read-only box; make sure lock/hold is not engaged
Posted on Jul 05, 2008
6ya staff
SOURCE:
What I must do, to format a memory card which is protected, by using a computer?
What type of memory card?
If it's a Secure Digital card, there's a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 03, 2015 | Cameras
How do i remove the write protection on my galaxy s sd card
need to remove the write protection from the PHONE MEMORY so i cant delete anything . remove-write-protection-galaxy-s-sd-card-0mcgnre0akckbqsgiub3i30g-3-0.png
kindiy anybody help on this
May 25, 2012 | Samsung Galaxy S 4G Cell Phone
When I try to put music on my phone the computer says cannot copy song. The disk is write - protected. Remove the write - protection or use another disk. I could put music on my old phone. How do I remove...
If you were trying to put it on a memory card... Some memory cards have a little switch on them. Take it out, position the switch differently and try again. I hope it'll help. Thank you
Jan 15, 2011 | Computers & Internet
When i try to add music in to my card adapter pny SD 2 gb it says it has write protection and to take it off what do i do?..
To remove write protection
In your memory card adapter have a switch to on/off write protection.
pull this switch to down ,you can remove write protection of your memory card
thank you
Dec 23, 2010 | PNY 2GB microSD Memory Card
How do i transfer already downloaded music from my pc to my lg gs390?
You need to have an PC suite installed in your computer for you phone to be recognized when connected to computer through an USB.
PC suite is specific for each ad every model of phone and it comes up with the phone in the form of a cd when you bought the phone..
If you do not have an PC suite , but if your phone is having a removable memory card then you can proceed as follows:
Buy an memory card reader which allows you to insert the memory card into the slot on the reader and connect it to the computer through USB port on the computer.
In both the cases the phone memory area would have been detected as an icon in the My Computer section of your phone and you can now transfer the downloaded music to that area...
Sep 24, 2010 | Cell Phones
How to remove write protection from memory card
Try sliding the button at the side of the memory card. It may be set in protect mode. Once done, you can add files to it freely.
Hope this helps.
Fix14
Jun 16, 2010 | Nokia N70 Cellular Phone
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
IMPORTANT G1 Question need Help now!!!!!
Put it in your PC and format it such that it allows for more items - music - to be added to or removed from the memory card whenever you waht to do that. That way, it will allow you to add and remove music whenever you want to do that, and it will not lock down the memory card. I have done the same thing with my 32 GB Flash Drive, and it works like a charm.
Jun 08, 2009 | Google Android
How to remove write protected memory card
hey that is because your nokia phone need to format to format any nokia phone
1-close your phone
2-put your memory card in it
3-press on the button that you answer any call from it with * with 3 whith the power button all of them togethier whe the phone is closed aND IT WILL START FORMATING
Jul 26, 2008 | Nokia 3110 Cellular Phone
Getting 4GB Micro SD to work
The card will not add to the MP3's memory, it shows up as a removable disk on Windows Media Player version 11.
Otherwise, you can manually drag & drop files thru My Computer>Removable Disk (*).
FYI, the memory card will only support un-protected MP3 files, not Rhapsody or other subscription content. Also, you will need to free up some space on the player to allow some free space for the database to accommodate for the additional music.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa e250 MP3 Player
iLO (2 GB) MP3 Player Logo
20 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
