Question about LG enV VX9900 Cellular Phone
Cracked lcd screen on inside not plastic cover
I opened my phone after work one day and the inside LCD screen was ruined. There is no damage to the plastic cover on the screen, just the LCD behind it. It must have dropped or been squashed.
  • 1 more comment
  • Jake Kuk Apr 03, 2008
    Can it be fixed?
  • Thechez May 21, 2008
    My screen on the inside is cracked pretty bad. On the out side of my enV the screen is black but at the top left corner you can see a little crack. I really need to know how to fix it. I even tried to call someone but i cant hear. Please help me.
  • trivonp Jun 13, 2008
    both of my screens are cracked
Goooooooooooooooooooooooooooooooooooooooood
Posted on Nov 08, 2008
  • Anonymous Nov 08, 2008
    gooooooooooooooooooooooood
    Problem Solver:
  • 10 Answers
No. Needs to be replace...
Posted on Apr 04, 2008
  • 113 Answers
I went to WWW.HTCLCD.COM for my replacement LCD only cost $35 and came with the T5 Torx screwdriver
Posted on Apr 06, 2008
  • Anonymous Nov 25, 2010
    This site no longer offers a solution to the screen replacement problem. Tryhttp://www.yallstore.com/index.php?main_...
SOURCE:
Lg reset
Sounds like the LCD digitizer which either broke inside OR became disconnected. If the impact was not enough to sustain a screen crack, and you have warranty with either LG or through your carrier, you can get LG to fix it free if there is no physical damage, cracked screen, or water damage, with your carrier, it would be the easy, just tell them the screen isn't broken, the phone is intact but the screen is blank. That is a hardware failure... they are supposed to be able to withstand some drops so it really depends on how much physical damage there is.
A digitizer LCD is not expensive and there are ways to change them fairly simple since the screen isn't cracked, you go through most LG phones via the back, remove the camera, remove a black cover that holds the sim and or memory card, BE CAREFUL and please look at youtube to see a complete disassembly of your particular LG phone.
Jul 16, 2014 | LG Cell Phones
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
Cracked screen, now lines running up and down screen
Its all one piece on the vu. as long as the plastic lens covering the lcd is still intact. Its a fairly easy replacement Ive done a few!
Mar 01, 2010 | LG Vu CU920 Cellular Phone
If I dropped my phone, and messed up the screen,
The LCD is cracked and needs to be replaced. A warranty is not going to cover it because it's clearly impact damage (though you can try). The LCD is hard to find and quite expensive.
Feb 03, 2010 | Pantech Duo Smartphone
Crcked screen
dude thats it mate game over
Oct 13, 2009 | Samsung SGH-A877 Impression Cell Phone
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
How to replace lcd screen on Samsung SGH A737
hi
If you just want to replace the plastic cover on the phone which is on top of the lcd screen then get a small screw driver and lift off the plastic from the top where the ear piece is situated. The plastic cover will lift of quite easily and you then just replace the clear cover with a new one. Make sure that you are in a dust free area so that no dust is trapped between the plastic screen and the lcd screen. You should be able to buy the plastic screen covers from ebay for under £5
OR
the lcd screen? hmm is it blank or cracked ... probably I would chuck it for the new cells are free with a contract, but if you have to ...
contact the manufacturer and order and a screen and get a set of tiny screw drivers to open it .. some are tricky and you need to figure out where they hide the screws .
REGARDS
May 27, 2009 | Samsung SGH-a737 Cellular Phone
Black oval spot on screen when turned on
The LCD screens are built with a over-cover of a plastic film and the LCD is inside the cover. Any damage on the LCD glass will not be felt physically on the outside of the screen. So, chances are your LCD is cracked if you find a spider web or a liquid spill effect visible.
Dec 26, 2008 | Haier Portable DVD Player PDVD7
I wnat to replace the screen
Hi there. If you just want to replace the plastic cover on the phone which is on top of the lcd screen then get a small screw driver and lift off the plastic from the top where the ear piece is situated. The plastic cover will lift of quite easily and you then just replace the clear cover with a new one. Make sure that you are in a dust free area so that no dust is trapped between the plastic screen and the lcd screen. You should be able to buy the plastic screen covers from ebay for under £5.
Hope that helps.
Gary
Apr 03, 2008 | Cell Phones
Outside screen cracked
take the phone to a mobile service center and have them fix the phone for you.
Sep 09, 2007 | Samsung SCH-u740 Cellular Phone
LG enV VX9900 Cellular Phone Logo
172 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
