Question about Samsung Digimax D53 Digital Camera
Lens stays neither closed nor opened when power off
Hello pros I need help.
The lens on my digimax cyber 530 will not close(retract) completely when I turn off the camera.
When I turn it on it gives a 'whirr ing' sound and then auto shuts off.
Out of desperation I have manually 'pulled' out the lens. it stays that way
until i turn it off and it retracts only halfway.
Can anyone help this senior? thank you kindly
  • 1 more comment
  • Anonymous Apr 10, 2008
    i have the same prob. it works when i pull the lense out or i tap on the camera, it works just fine then but when i turn it off the lense will not retract
  • cam60 May 22, 2008
    I guess I have to push it back in manually is the only solution if i want to keep this samsung? thanks anyway.
  • j1uss Sep 06, 2008
    when i switch it on the lens opens only a small amount and beeps 3 times then turns off - i have to shake the camera and wiggle the lens - turn it on again and the lens comes out- take the photo then turn off and all ok - then turn on again same problem.
Oh my camera have da same problem...........
Posted on Sep 22, 2008
    Problem Solver:
  • 10 Answers
Try to slightly push it in slowly while it is going in manully
Posted on May 07, 2008
When using camera, the lens will not come completely open or clos
You have broken last (black) gear in opening/closing mechanism. Common problem. Need new gear or fix missing "tooth".
Sep 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Same problem
The problem, it seems, is internal. Without the knowledge of the innards of a digital camera there isn't much you can do. You could return it to the company if it is under warranty. Or you could take it to a repair shop and pay almost as much as it would cost for a new digital camera.
May 08, 2008 | Samsung Digimax D53 Digital Camera
CANON POWER SHOT
My camera lens has opened but will not close and retract.
Jan 17, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Cybershot camera lens cover closed
Follow the steps below to troubleshoot if the lens will not open, retract, or extend. WARNING: There is a risk of hardware damage. Do not attempt to manually force the lens in or out. Doing so may damage the camera. NOTE: Because each of these steps represents a possible solution to this issue, check the camera status after completing each step. Ensure the battery is adequately charged or connect the AC power adapter (if applicable). Perform a power reset. If the camera lens is still not operating correctly after completing the troubleshooting steps suggested, service will be required. Hope this helps
Aug 23, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sansung digimax s5oo
close the lens on the camera all the way!
Oct 15, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax D53 Digital Camera Logo
124 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
