Maxtor Installl problem
I cannot get my Maxtor to show up with my other drives or open. I get the main menu with set up and resture and main managment, and security settings. When I click on one it says select drive you would like to view and that is as far as I can go. When I click next nothing happens. When I find manage Maxar one touch and click on it evert option takes me to the select drive menue
    Sergeant:
  • 349 Answers
If its an IDE internal drive:
it may be that you have not set the drive up via the jumpers on the rear of the drive,
if it is your second drive and you have it on the same data ribbon as the other hard drive ,set the new one to slave drive,
if it is on a separate ribbon going into the IDE2 socket on the motherboard set it as a master,
good luck & let me know how you go with that.
Terry
Posted on Apr 03, 2008
SOURCE:
Maxtor hard drive jumper setting for model 90871u2
12 Results that fit your criteria Prev Next Showing 1-10 of about 12 for 90871u2
May 09, 2012 | Maxtor Hard Drive
How do i open my maxtor external to see what is on there?
go to your (my computer) icon in the start menu and click it and then you should see you PC's hard drive C: , and your external one that is plugged in should be showing as well click on your external one and you should be able to see and read your files. the fixist good luck and have a nice day
Jul 01, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Want put additional hard drive in presario s6020wm is this possiable, also do the rpm speeds have to be the same I have a maxtor diamondmax plus 9 80g that spins at 7200, the one in the computer spins at...
It’s very possible to do and no it doesn't matter that each drive runs at different Rpm speeds.
The difference between a hard disk drive that runs at 5400Rpm and a 7200 Rpm is data transfer speed. The 7200 drive will run faster but the drives cache also plays a big part when transferring data. A drive that runs at 7200Rpm with a 16MB cache will run faster than a drive with 8MB cache. The 7200Rpm drive will run a little hotter than a 5400Rpm drive and use a little less power. Typically you’d want to use the 7200Rpm drive as the primary drive. (With windows installed on it).
The 5400Rpm drive should be used as a storage drive and be connected on the same data cable as a slave drive. How to safely remove data from the 5400 drive. Before you shut down the system, open windows explorer. Click on the C:\ than delete the Boot.ini, AUTOEXEC.BAT, and IO.SYS files. (By doing this the drive will no longer be bootable but all the data will stay intact). Shut down the system. Remove the 5400Rpm drive from the system. Install the 7200Rpm drive. (The new drive is an IDE drive. Set its jumper so it is a Master.) Guide to setting-up an IDE drive; http://freepctech.com/pc/001/installing_ide_devices.shtml
Set the jumper for the 7200 drive as a Master with a slave. (The 5400 drive will be added later).
Once the drive is configured and installed boot the system and enter the bios/CMOS menu. Press the delete key to enter the bios or watch you're screen you may need to press the F1, F2 key or F10 key to enter the bios menu. Instruction on how to move about while in the bios is shown at the bottom of the bios screen. You should see the model numbers of you’re 7200 DiamondMax drive within the main bios menu.
You will also need to set the boot menu / boot order.
Open the Boot menu. A typical boot menu would list as follows:
1st Boot device, Floppy disk drive
2nd Boot device, CD-ROM drive
3rd Boot device, Primary hard disk drive.
4th Boot device, not needed
Compaq does not provide bios settings within their user guide. Before you save and exit the bios, open the CD-ROM drive and load you're windows CD or the restore CD from Compaq. Save and exit the bios. When the system reboots it should start up the windows CD or the restore CD. Follow the on-screen instructions from the restore CD. Once windows is installed update windows. When finished it is now time to add the old 5400Rpm drive. Shut down the system. You will need to change the jumper on the on the 5400Rpm drive. Set the jumper to Slave and insert it into an open bay. Connect the data cable and power cable. Check that all cables are fully connected. Boot you're system. Windows should load. You're 5400Rpm drive will most likely be labeled as letter E. You can change the drive letter order by opening the run window. Click Start and in the run window type in: diskmgmt.msc than click ok. Open Help. Click, help topics. Click on disk management.
Compaq Presario S6020WM Desktop computer web site;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00058482
User Guide for S6020WM
http://h10032.www1.hp.com/ctg/Manual/bpb13287.pdf
Cheers'
Mike
Feb 01, 2010 | Compaq Computers & Internet
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
Jan 02, 2010 | Maxtor Hard Drive
My hard drive stopped reading out of nowhere,as it tries to boot up it makes a clicking noise about every 10 to 15 seconds,it is a maxtor,I recently updated drivers for what i belive was my video card and...
It is enough info:
It is possible that the hard drive is bad (clicking noise - not good); however, try this:
1. Turn ON computer and get into the BIOS (probably by pressing the "del"ete key).
2. Go to the "Boot sequence" menu and make your Maxtor the FIRST boot device. (If CDROM is first, that's ok, too as long as the Maxtor is the SECOND boot device then).
3. Save changes (F10?) and start Windows (hopefully).
4. If it still doesn't work, go back to the BIOS settings and select "Use default settings". This will reset all BIOS settings to the factory settings. & try to boot Windows again.
5. If it still doesn't work, maybe you disturbed the hard drive (Maxtor) cables if you made any physical changes to the computer.
6. If so, or for the heck of it, open the computer and re-seat the cables on the Maxtor drive and motherboard.
7. Try again ...... or *sigh* replace hard drive.
Hope this helps!
Sep 03, 2009 | Computers & Internet
Vista is not picking up my maxtor harddriver but wheni had xp was .
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
May 30, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
