Question about Refrigerators
I need help to level my kitchenaid fridge, and the owner manaul does not show this.
    President:
  • Refrigerators Master
  • 2,651 Answers
Leveling refrigs, can be abit tricky, depending on level of floor especially, for the most part only the front 2 legs/wheels are going to be adjustable, the rears if need be will have to be chocked with wood shims . as a repairman for nearly 20years, i rarely "level" refrigs, , for the reason of who knows if the cabinets are level, or how level the floor is, i in turn make the refrig appear level and make sure its stable when the doors are opened and closed. not essential for level (shloud be close butno need to be perfect, id much rather a refrig tht looks good and doenst shake when door is closed, rathe then tryin to get it perfectly level and then seeing a 2 inch gap at top of cabint and flush against the bottom.
Posted on Apr 03, 2008
Owners Manual for Mitsubishi M-VR400 receiver
Go on google, Type in manauls online.com.You can download a manaul for no charge, If they have one for it.
Oct 21, 2012 | Mitsubishi M-VR400 Receiver
NEED A OWNER'S MANAUL
follow up link for PDF :
http://www.2shared.com/document/PgcG1IaT/RS2656_manual.html
Nov 29, 2011 | RCA RS2656 Shelf System
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not making ice in refrigerator.
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath the freezer needs to be0/4degrees to start if not that cold may need freonor compressor my be weak.
Aug 09, 2009 | KitchenAid Superba KFRS361TSS Stainless...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Owners manaul
Hello there:
if you go to www.palomar.com and look for the user manual they will have it there ok
best regards mike
Jun 29, 2009 | Midland LXT310 2-Way Radio
Leveling new Kitchenaid Fridge
Hi, Remove the front kick plate and locate the adjustment screws in front corners. Usually 3/8" or 5/16" head bolts.
Realize, there is only so much adjustment. You might have to level the back side with thin boards or shims.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | KitchenAid KSRV22FV Side by Side...
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Fridge door is lower then freezer door
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
May 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Turns on randomly Reads: PAN and then counts down from 3 minutes
From the owner's manual found here or here:
"Touch PAN HEAT once. Pan will preheat for 3 minutes."
Sounds like it's doing it on its own due to a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 13, 2008 | KitchenAid KHMS145KSS Microwave Oven
Refrigerators Logo
396 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
