Samsung Menu hieroglyphics.
Menu and Display items shows up as hieroglyphics on Samsung TXL2767 TV. It's an old TV, and schematics are $28 from Samsung.
  • 149 Answers
It may be in caracter generator of micro prossesor and probsble mor expensive than tv if you have good picture live it as is if you whant to fix it take it to a local shop and get estimated
Posted on Apr 03, 2008
Samsung led TV 28' bad display after two second raster plane & various color show on display
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 31, 2016 | Samsung Televison & Video
How to hide my number in samsung e2121b
Hide or Display Your Number on Samsung GT-E2121B
1.Go to your menu and select Settings (round gear wheel thingy).
2.In the settings environment, select item no 6 - Application
3.In the Application environment, select item no 1 - Call
4.In the Call environment, select item no 1 - All Calls
5.In the All Calls environment, select item no 1 - Show my number
6.This gives you the following three radio button options:
i.By network
ii.Send
iii.Hide
Select iii. Hide, then exit to return to your phone interface. All calls will not display your mobile phone number to the recipient.
To reverse this and display your number in subsequent calls, repeat the whole process and at step #6, then select i. By Network. Your mobile phone number will now display to call recipients for all calls.
Jan 02, 2012 | Samsung Cell Phones
What's your problem?
First, make sure this isn't coming from your signal source; these items are not listed in any of the functions described in the manual for your monitor.
If disconnecting, changing or turning off your signal source doesn't get rid of the control item display, try resetting the monitor (maybe the display has some extra firmware features not in the documentation):
  1. Press the Menu button on the side of the monitor.
  2. From the On-Screen Display, navigate to the Setup&Reset menu using the arrow buttons, then press the Source/Select button.
  3. Navigate to "Reset" and select it.
This should restore everything to the factory default setting and get the TV/monitor out of whatever mode it's in.
Dec 03, 2011 | Samsung 23IN Led 1920X1080 5M1 PX2370 Dvi...
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
May 27, 2009 | iLO 3200 32 in. LCD Television
Universal - remocon settings
I need the code for the Sumsung Universal Remocon for my Samsung TV model TXN2726. It is an older TV 2003 model. It was given to us recently but the remote needs to be programmed and we weren't given the programming code.
Jan 20, 2009 | Samsung TXL2767 27" TV
Watching new two day old le37r87 and the screen just went black now does nothing but the soulnd still comes out of the Hi-fi
Does bulb come on? If not, I would take it back since only 2 days old. If it does, try unplugging for a few minutes and plugging back in to see if that solves problem. If not, you can check test patterns by getting into service mode to see if display is working. Not sure what code to get into service mode on your tv is, but I have a different model Samsung and I enter service mode by pressing "mute", "1", "8", "2", then "power" on the remote. If your samsung has same code, it will start up in service mode. Once in service mode, go to DDP1011, then Test Pattern. Go through the different patterns by pressing the right arrow key on remote. If they don't show up, you probably have bad DMD board. If they do show up, go back to main menu and select DNle then Test Pattern. If pattern does not show up, you have an analog board problem. If it does show up, go back to main menu and there should be an option in the menu tree to do a user reset, which will change everything to factory defaults and restart tv. Hope this helps. If not I would be taking it back since only 2 days old.
May 16, 2008 | Samsung Televison & Video
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
