Question about Samsung LN-S3251D 32 in. LCD HDTV
Connecting ipod to samsung lcd tv
I connected the av wire and I did the red in yellow, yellow in white and white in red connection. cant get tv to connect to ipod.
How to connect I-pod to samsung lcd tv
Posted on Oct 16, 2009
If it is not the apple brand cord then it can still work. apple has changed there ipods so that the sound and vidio come out of the opposite port exmple: white comes out of yellow and yellow comes out of red. so all they did with there cord is switch the colours around. by doing this they forced people to buy there 50 cord witch really is the same and any avi cord but with the colours switched around . so just try different combonations with the colours
Posted on Jun 25, 2009
I have this TV that is a 2008 samsung but i cant hook up the cable line because i dont have a cable box i only have the coax cable line comming out of the wall in my liveing room, problem being is that...
If you have an older VCR, you can connect the cable to the vcr "in" , then connect the A/Vcables from the video and audio out of the vcr to the A/V on the set and put the set on av1 for source. If you don't have a vcr then you will have to get a box.
Nov 27, 2010 | Televison & Video
CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
May 02, 2010 | Televison & Video
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
How to connect Apple iPOD to Sony Bravia LCD
http://www.applesource.com.au/ipod/soa/Play-back-iPod-videos-on-your-TV/0,2000070791,339287576,00.htm
Connect your iPod to your TV with a DIY cable
The iPod A/V Cable is stylish and handy, but you may feel it's not worth the money; the Belkin cable gives you twice the value per foot but costs the same overall. For a less expensive alternative, find a standard A/V cable with three RCA plugs at one end (coded red, white, and yellow) and a 1/8-inch A/V plug with three bands at the other end.
To set up your iPod for playback, plug the 1/8-inch connector into your iPod's headphone port, and then plug the yellow, white, and red RCA connectors into the RCA jacks on your TV in this non-color-coded way:
Jan 19, 2009 | Durabrand DU1301 TV
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Ipod av cable
Some help on this problem direct from the horses mouth.
Click here.
Jan 10, 2008 | Audio Players & Recorders
Samsung LN-S3251D 32 in. LCD HDTV Logo
1,824 people viewed this question
Henry  Thomas
Henry Thomas
