LC-32d40U Sharp Aquos Screen shows "please wait" controls do not respond
We just turned on our 32" wall mounted Sharp Aquos and the screen came up with a "please wait message" The set froze, it would not respond to the remote or to the set mounted controls. We powered it down for about ten minutes and tried again and the same thing occured. I have noted from some of the blogs that this has been an issue with Sharp LCD's. I would greatly appreciate it if someone could give me some insight as to the possible cause and solution
  • glease6 Mar 15, 2009
    please wait controls do not respond
  • Anonymous Mar 21, 2009
    same here
  • 372 Answers
Hi.
Im not familiar with your TV set as it is made for USA but here in the UK some sharp models suffer with similar problem & this is the remedy.
As I said I cant gtee it will sort your problem but give it A try.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. This should hopefully clear the problem.
  3. http://dysonmanuals.llc.nu/
Posted on Apr 03, 2008
Sharp Aquos LC-40C32U: Black screen, various vetical colored lines for extended period after turning tv on (volume button changes appearance of vertical lines)
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots do defective LCD panel are given. You can see and compare it to that of your TV's.
Apr 21, 2014 | Sharp Aquos LC-32D40U Television
Can't find tv stand for Sharp Aquos LC-32D44U
You can get a universal stand from shopjimmy.com. It attaches to the back of the TV just like a wall mount.
Aug 15, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
Nov 15, 2009 | Sharp Aquos LC-32D40U Television
Performed ground repair, now screen is blue, sound ok
I would suggest to check the wire connecting the main board with the LCD controller board. It might have been disconnected when repairing the ground connections.
Jul 26, 2009 | Sharp Aquos LC-32D40U Television
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Probelm with wide screen display .
Check your VIEW MODE button instead ....
Aug 17, 2006 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
1,101 people viewed this question
Top Televison & Video Experts
