Question about Sony Playstation 3 (PS3) Console
Ps3 setup we just got a ps3, brought it home & hooked it up but it will not "talk" to our tv though our ps2 does with the same setup. what do you recommend we try?
  • strtfrmfla Apr 03, 2008
    I have had my PS3 since December. I turned it on and then it froze. I then reset it and now it will come ,but it won't show up on the TV. Somebody please help me.
  • Anonymous May 11, 2010
    If you are hooking it up to a/v cable. Unplug a/v cable and boot up ps3 first then plug in a/v cable to console.
  • 27 Answers
Plug the PS3 in as normal, turn on the console from the machine not from the controller, and hold the button for about 10secs. The PS3 will come on and then restart itself. Once it has restarted it will use its native resolution and you should be able to see it fine.
Posted on Apr 03, 2008
SOURCE:
How to put playstation where it will show on a regular TV that does not have HD my son took his playstation over his friends who had a HD TV when he brought it back home and hooked it on same TV they had...
With the ps3 already on standby, hold the standby button with the television on the correct channel until the display shows, it will take quite some time. Then change your setup accordingly.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
How do i hook up ps3 slim hdmi?
there isnt a ps3 slim and if your talking about a ps2 slim they dont have any hdmi hook ups.
Sep 02, 2009 | Sony Playstation 3 (PS3) Console
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
Connecting PS2 to Bose Lifestyle 18
we use the AUX for our PS2 and it works just fine and use the yellow cord into the video in on the tv, the red and white into the BOSE
Dec 27, 2008 | Bose Lifestyle 38 System
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 PROBLEM
bear with me i'm working on a solution for you just be patient we will get it figured out
Sep 06, 2008 | Samsung DLP HL-P5663W 56" TV
Hooking up a PS2 & PS3
Hey Jason2312,
Depending on the number of connections available on the back of your TV, you may have a number of options that you can use to connect both consoles.
Both the PS2 and PS3 have the ability to connect to TV's and other devices (like VCR's) using composite, component and S-video cables. The PS3 also has the added perk of being able to use HDMI connections, which weren't necessarily available when the PS2 was initially released. If your TV has any combination of two of these connection types available, you should be able to directly connect both consoles to your TV at the same time.
The only thing you'd want to keep in mind is that you may need to change the signal input on your TV, depending on what console you want to use. Many TV's are only able to support one device on their standard input station (usually channel 3 or 4), and can only support additional devices through antenna or satellite input stations - you'll want to see the owner's manual for confirmation of your TV's capabilities and limitations.
In the event that you do not have multiple connections available, you can generally purchase a system selector that can be used to connect several devices to the same ports on the back of a TV. These can usually be obtained from a local retailer for anywhere between $20.00 and $40.00, though more expensive models may exist. Two of the more common names you may wish to look out for are MadCatz and Pelican Accessories - both are specialty companies that tend to cater towards the gaming audience.
Additionally, some home theater systems and receivers may also have similar functionality, but please keep in mind that you'd probably be looking at a much larger monetary investment if you purchase an entire home theater system instead of a stand-alone system selector.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 20, 2008 | Sony Playstation 3 (PS3) Console
Hooking up playstation 3 to tv
you need a ps3 scart lead. i think the one of the ps2 is the same but check. it should just hook up like a ps2. if you are having any problems with the picture hold down the power button when you start up the ps3 for 10 seconds this runs the optimal screen settings for the cable you are using. but if it is the first time you are using the ps3 it will auto start in set up mode. hope this helps
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
