During spin cycle the machines walks away from the wall.
  • Ron Coons
    Ron Coons May 11, 2010
    whats the make and model of unit, how old is it and has it always done it??
If this is a new Bosch washer, then did you remove the 4 Transporter Bolts from the back? This is very important because it holds the drum tight so it doesn't move while it's being tranporting. Loosen all the bolts starting from the bottom 2, but do not remove it yet. Once all is loose, then remove the bottom 2 first, then the top 2.
Posted on May 04, 2009
Starting with least expensive solutions
1. Make sure load is balanced
2. Make sure washer is level with all 4 feet touching the ground
3. Take apart metal shell and look for broken suspension cables
4. Inspect transmission boot to see if it is loose.
Posted on Apr 03, 2008
    Genius:
  • 1,198 Answers
A load too small won't balance. A load too large will overwhelm the machine. Check the feet, usually the front ones may be adjustable,(level the machine left to right) and the rear ones may have a self-leveling apparatus that could get jammed. It should be free to move.
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Kenmore elite type 580 no: 27087603 works well machine has been leveled and load is balenced yet it sound like theres a train running past in your back yard ' why so loud
Lol, the spin cycle on them is so powerful it will walk around your uitlity closet. Unly suggestion is to use wood or some other wedge to make a tight squeeze between the machine and the wall. This will keep the spin from allowing the machine to move or make loud noises.
Sep 20, 2012 | Refrigerators
When in spin cycle machine made a loud noise then the spin cycle continued but very loudly. the machine would continue to wash clothes as normal and then get loud during the spin cycle again. at this point...
Hi if you can do it yourself, put the machine about 2ft away from the wall with the door faceing the wall,then lean it against the wall,this way you can look under the bottom off the machine,check to see if the drum moves from side to side,some times the shock absorbers come loose 1 at each side,all the best.
Jun 15, 2017 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Washer in high spin cycle "walks" slightly away from the wall although when I put a level on it it appears to be level. The floor vibrates when it is in this high spin cycle. Feet are not raised very much...
make sure all the pegs are touching the ground. You may have the vibration dampner going out or the weight on the wheel is loose. You can find all that by unscrewing the back of the machine
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
