Question about Maytag Atlantis MDG6400AW Gas Dryer
MAYTAG atlantis MDG6400AW, dryer not heating
Last night the dryer was on all night.  I thought it was strange when it was running this morning.  Now I realize that there's no heat.  I have no prior experience fixing this.  Can you tell me what needs to be done?  I wonder if this is expensive if I call a repair person.thanks!
  • 1 more comment
  • Nahla732 May 11, 2008
    same problem
  • Anonymous Jun 03, 2008
    nnn
  • Anonymous Jun 23, 2008
    Yes I have the same problem. But I did replace the sensor on the side of the flame chamber or duct. It worked good for one night then returned doing the same thing. I checked the coil or part that sits on top of gas line, this part has two different connectors on it. It was very hot to touch, could this be over heating? It seems dryer works for a short while then no heat or flame heating coil becomes bright red to light gas, but no gas.
4 yr old Atlantis 7400 with the same problem. Gas valve coil kit fixed it. $43.00
Posted on Jul 31, 2008
    President:
  • 1,314 Answers
No we can fix it its proab a heatyer coil or thermial limiter if you reply ill help mater of fact did you have it on auto dry ?
Posted on Apr 04, 2008
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Atlantis MDG6400AW Gas Dryer: there is no heat...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 18, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis dryer MDG6400AW
There is a technical data sheet in behind the the control panel if they didn't hide it somewhere else. It's there somewhere. Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I have a maytag dryer and when you start it the timer doesn't move - it will run for hours unless you stop it. now when you pull the knob to start it doesn't respond
Sounds like the problem is in your timer contacts, in which case you would have to replace your timer. A no heat scenario on auto dry could also cause a dryer to run continuously.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
290 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
