Question about Whirlpool Duet GHW9150P Front Load Washer
How do we get a pen out that is stuck inside under the drum somewhere/
There is pen that somehow got inside under the drum. How do we get it out?
    President:
  • Whirlpool Master
  • 2,651 Answers
A pen???? thats a good one.. you can removce the lower access panel (3) torx 20 screws across bottom of the unit, after that youl see the pump is rigth in front of you with a beige plastic screw opener(button trap). you can open this and retrive any other debris that has fallen betwwen the tubs an dcaught hther before entering th pump assy. BE WARNED THERE WILL BE WATER BEHIND so be prepared,i usually open a tall kitchen garbage bag to catch the water. after its all empty, follow the hose leading to the bottom of tub assy, and remove there it willgive you a 3in access port into the bottom of tub, hopefully your pen is on bottom asnd you be able to grab it though there
Posted on Apr 05, 2008
I have LG 6kg WP9032 machine. When i operate drier a peculiar sound is coming. Looks like something is stuck underneath the drier.How
Stuck under where ??? Between the drum and the housing inside ? Many times underwires from bras that come loose will get caught between the drum and make a squealing/squeaky noise.. look inside along the edges of the drum and see if you can see anything unusual sticking out..sometimes rotating the drum manually helps find it.
Jan 23, 2018 | LG Washing Machines
THE PRINTER IS NOT FEEDING, 5 YELLOW LIGHT IS FLASING
Sounds like a paper jam. Posibly from a ripped peice of paper stuck somewhere inside. Also disconnect it, tip it over and shake it in case a pen or paper clips fell inside the feed end. My kids have done that to me before.
Jan 28, 2011 | Canon i860 InkJet Photo Printer
Somehow a ball point pen went into the dryer. I now have ink on the inside of the drum. What can I do to get the ink off the drum. It should be noted that the dryer weny through a complete cycle before...
You may have to experiment with solvents to find one that will remove the bulk of the ink. Start with rubbing alcohol, then try a mineral spirits (paint thinner) or WD-40 oil, and finally some acetone. Make sure there are no sparks or fire nearby while using these solvents. Be sure to clean the areas with a spray cleaner after any success to remove a lingering smell. You may have some permanent stain left that will just have to wear off, but shouldn't affect your clothes. Hope this helps!
Dec 11, 2010 | Whirlpool Dryers
We are getting black marks or lines on wash.
maybe an ink pen trapped somewhere if you dont see anything scrapping the inner drum try taking inner drum out see if something stuck under there
Aug 01, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
I have the GLEQ212ES1 dryer. When it is running. it sounds like something is rubbing against the drum. When you turn it by hand manually, the drum is harder to turn.Could a piece clothing gotten stuck...
Although this is possible, usually one of the wheel bearings may have gotten dry or even is stuck. Inside there are wheels that the drum is steadied by and that rotate with the drum. If it's a year old it should be under warranty and a tech can fix it. If that is a problem, remove the back (after unplugging it) find the wheels and rotate the drum by hand. If a wheel is stuck or dry you will find it. I hope this helps.
Jul 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Sticker label stuck inside
Depends on where inside the machine the label got stuck. There's covers on the back, front (which also lets you remove the toner/drum unit for more access) and also the paper tray.
If you're unable to reach the label removing these parts/opening the covers, the machine would require to be screwed apart to reach it. There is no levels to release pressure on drum or similar to reach further within, unfortunately.
Jun 02, 2009 | Brother HL-2040 Laser Printer
Ring somehow got through to drum mechanism
it shouldnt take much to get it out.call them in and have them pull it out so it cant do any other damage to the machine
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Jan 18, 2009 | Wacom (EP130EPE) Digital Pen
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Cleaning it out with rubbing alchohol?
the outside and under the cap for the joystick :) e-mail me at fixya (at) whypayforhelp.org
Jun 19, 2008 | C-Technologies C-Pen 600C Handheld Scanner
Whirlpool Duet GHW9150P Front Load Washer Logo
243 people viewed this question
Dan Webster
Dan Webster
Sal De
