Question about Miele Dishwashers
Miele G646 dishwasher. This dishwasher has a ventilation vent on the front panel. During the drying cycle the dishwasher is now making "choking" noises through ventilation vent and when complete and open door water pours out of the ventilation vent. This machine is about 5 years old. Regards Nic
    Novelist:
  • 269 Answers
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Posted on Oct 16, 2013
Yes solved by pulling door apart. There is a small drain tube from the bottom of the ventilation vent, which had some blockage.
Cleared it put door back together and now works just like new.
Cheers
Nic
Posted on May 25, 2008
I have the same dishwasher and the same problem have you been able to sort it out yet?
Posted on May 23, 2008
SOURCE:
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Miele G646 SC plus I wish to remove the right hand side panel of my dishwasher. I have managed to do this with the exception of the top of this panel. Does the top surface have to be removed to release...
Hi - if i rember correctly on the sides front top panel is a plastic bung, pop this off and you would see the screws inside - oly problem is most of the later Mieles have torqx screws - anyway if you succeed the gently lift front & push backwards - the top will come off.
But the best ways is to empty the washer of water pull it away from the cabinets disconnect everything.
Lie the silly thing on its back on the bottom will be 4 screws normally this will drop the bottom panels & makes it easier for you to work on the machine.
According to the parts manual this would have a waterproof inlet valve system - typical design for Mieles.
JUST BE CAREFUL - Mieles are excellent machines, try not to damage other components - perhaps the leaks is coming from some other - Miele parts are as costly as the purchase prices.
Hope to see how you get on...
Jun 23, 2011 | Miele 24 in. G646SC Plus Free-Standing...
Hi Service, I have a Miele dishwasher model G692 SC Plus which has a problem with the drying fan filling with water during the wash cycle. We open the door at the end of the cycle and water drains out...
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Jan 16, 2011 | Miele Dishwashers
The little vent above the words turbothermic plus is spitting out water during the cycle.
The fan assembly's drainage path is clogged. With time, food residue cloggs up the drainage path, inside the "Turbothermic" fan, and water accumulates during the drying cycle. The control panel, that houses the fan assembly, will need to be removed. Door panels will also need to come off. Unplug wires and drain hose to the fan, and loosen the round fan grill that secures the fan assembly (located inside the door). Take apart the fan assembly; unclogg drainage path and hose; and wash all parts. Re-assemble, install, and plug, the fan assembly, drain hose and door panels. Good Luck.
Oct 27, 2010 | Miele Premier-Plus Built-in Dishwasher
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
I have a Miele G 892 Dishwasher and recently the vent for the Turbotronic drying fan has been sticking in open position at the ned of the cycle. Teh result is the next cycle the vent fills with dirty water...
You'll have to take the door panel apart. There's a small drain hose between the turbothermic unit and the detergent dispenser. It's most likely clogged.
Feb 22, 2010 | Miele G880 Dishwasher
The drying vent on the front of our miele dishwasher is leaking water and the fan is making a lot of noise at the end of cycle
if you remove the door panel you will see a small hose from the fan to the combi dispener. Remove this and blow through it. Also connect it to the combi dispener and blow and then to the fan end and blow. Food and muck block the pipe and the excess water cannot escape back into the unit so instead it pours out the vent. you will find the fan is then quieter.
Feb 05, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
May 19, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Drying cycle vent fan is noisy. How can I fix it
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Dec 31, 2008 | Miele 24 in. G865 Built-in Dishwasher
Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Mar 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
1,371 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
