I have a compaq laptop the screen will not come on all the time and when it does it gets a faint background light without the normal start up routine
  • 111 Answers
What`s the model #
Posted on Apr 03, 2008
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario b1900 fails to give output to monitor. If output comes out it gives blue screen and shuts down. If you switch on again the fan and disk do run but no output to screen. An external monitor...
That blue screen and shut down, means a problem on both OS and Hardisk.
If you got any hardisk for that laptop. try it and am sure it will work.
The faint beep means a good memory card.
Hope that helps!
Dec 02, 2011 | Compaq Computers & Internet
My laptop is not working! Help!
Try connecting an external monitor to your laptop and see if you get a signal to it. If you do, go to control panal and check the setting for your video output. If you replaced the inverter and still no video, you lcd may need replacing. Easy to do, just may cost you a litlle for the lcd unit.
Franklin
C2Solutions
Jul 28, 2009 | Computers & Internet
Faint image in the background.
Hi Nate,
The same thing has happened to me before.
Well, once you drop your laptop a lot of things could go wrong. From a broken driver to a cracked screen. I believe you broke your bulb. And the cells of your laptop are kinda messed up we can say. Yes, this is fixable but will take time. I hope everything goes better!!
Good Luck
**dont forget to rate**
Jul 10, 2009 | HP Pavilion xh555 (F3929H) PC Notebook
Compaq
Check the connections on the back of the screen and on the board. If those are good, it's either the screen or the inverter.
Jun 10, 2008 | Compaq Presario Notebook
I have a Packard Bell Easy Note R1910 with a start up fault
Does the hard drive/thinking light blink for a minute or so like it's going through it's normal boot routine without an image? Can you hook up an external monitor? If you take it into a pitch black room do you see any image at all? If it's there but faint then chances are the backlight has a bad connection or is dead and would need to be repaired.
Dec 07, 2007 | Compaq Presario 700 470024-192 Notebook
It's all black
If you power it on, take a flashlight and shine it on the lcd at and angle and look real close to see if you can see a faint image. If you can, then your backlight in the screen is not working.
Also, you can attatch an external monitor to it, while its off, then power it on and see if it lights the external monitor. Try that and let me know your results.
If you get a picture ok on the external, and you can see a faint image on the lcd using a flashlight, then it could be the backlight inverter board or the bulb itself inside the lcd went out.
If you don't get any picture at all, using an external monitor and can't see a faint image on the lcd using a flashlight, then I would say there's other problems with the laptop itself. Could be a mainboard problem, power issue, etc..
Oct 24, 2007 | Compaq Presario X1000 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
