Question about HP Photosmart R927 Digital Camera
R927 will not power on.
The camera will not pwer on. I have tried multiple batteries. It acts like there is no electrical energy getting to it.
  • Anonymous May 16, 2008
    Camera switches on when in the dock but not otherwise.  I have replaced both the battery and the dock station. I have tried to scratch battery contact points inside and on the battery as suggested by another visitor to this site.  Still nothing.
  • Anonymous Jun 18, 2008
    I have the same problem, the camera just wont turn on no matter how long I charge it.
I had this problem with this camera when i had it new i would put the camera on the dock to charge and then use it then finally it wouldnt work and i realised that the camera wasnt charging. i contacted hp who i found to not be very helpful, they eventually sent me out a new battery even tho i told them i felt it wasnt the battery, of course the same thing happened with the new battery. i called them again and said i felt that there may be a loose connection in the wire going from the transformer to the dock as by messing around with it had made the light come on but as soon as i let go it went off, they agreed to send a replacement. when the replacement arrived they sent the part of the cable that plugged into mains and as such was no use, they siad they would send the right one but as yet i have not received it. =S however, by moving the wire where it plugs into the dock i have manged to get the camera to charge, it may be worth messing with the wire to see if this is the case with urs and calling for a replacement. claire xx =D
Posted on Jul 17, 2008
When i want take a picture it alway says charhing the flash??? why to charching the flash??? please help me.... thanks you
Have you tried fresh batteries? If it has a rechargeable battery, try plugging it in to recharge over night. Also check your camera settings; red-eye reduction may decrease the power to make the make the photo or a constant auto-focus.
Feb 08, 2012 | HP Photosmart R927 Digital Camera
Hp photosmart R927. No power, no operation, no LCD, battery good.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 28, 2009 | HP Photosmart R927 Digital Camera
My Photosmart R927 will not turn on. I installed
Assuming that the new battery was the correct type and that it was fresh/fully charged, your problem may be due to or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 12, 2009 | HP Photosmart R927 Digital Camera
Not able to charged battery nor power the camera. The camera is completely dead.
Do make sure you have new batteries and new charger. If problem persists, then I would have the charging circuit may need to be tested or replaced
Aug 14, 2009 | HP Photosmart R927 Digital Camera
My camera is frozen it won't do nothing
How long did you wait before reinserting the battery? (30sec - 1min?) Did you try it with any memory cards removed?
Feb 27, 2009 | HP Photosmart R927 Digital Camera
Using SD HC Memory Card with HP R927 camera
No. The R927 is limited to SD cards 2GB and smaller.
Aug 25, 2008 | HP Photosmart R927 Digital Camera
Camera turns off
Are you sure the battery is holding a charge? you can get one off of ebay pretty cheap. Just to check. It is acting like a battery issue but it could be a damaged lens that can cause the same out come. I hope this helps lead you to a easy repair.
Mar 28, 2008 | HP Photosmart R927 Digital Camera
R927 digital camera
Are you sure that the battery is holding a charge? If it is holding a charge check the contacts on the battery and inside the camera. you can clean both of them with a pencil eraser gently rub the eraser on the contacts and this will clean them. I hope this helps you out and fixes your problem.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
R927 wont turn on
Remove battery and clean contact and then try.
Make sure the battery is fully charged or fresh
If still in trouble contact HP Support
Nov 27, 2007 | HP Photosmart 935 Digital Camera
HP Photosmart R927 Digital Camera Logo
69 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
