Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will not eject. Also it will not come out of DVD mode. I have tried unplugging it for as long as over night also I have tried holding eject button down as I reapply power. Still no help. I'm thinking I may have to pull the cover and try to get the disc out manually and hope without the disc in the tray the machine will reset itself. Any suggestions?
  • twotrey Jun 17, 2008
    Also have a Philips 3455H model, put in a DVD that has worked previously, got stuck, now when I plug in and power on, it just turns on the power then turns off repeatedly. Wondering if there is a way to manually release. Thanks.
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Posted on Nov 20, 2008
I have a Magnavox MRV700VR. I can record on a DVDR, but when I try to record on a DVDRW it tells me "disc error". Why?
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
Jan 28, 2013 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I cant burn any dvd, but cd r or rw are capable . mayber the driver is out of date..please help me.
hi
perhaps the CD media you purchased is not compatible with your CDROM drive ..?
what is the model number oif the CDROM ? what computer model is used in ?
Nov 15, 2010 | Computers & Internet
My recorder DVDR 3330H has the "finalize" in the menu disk but I cannot click on it .
Probably you don't have a DVD+/-R disc inserted but a DVD+/-RW. A rewritable disc can't be finalised and doesn't have to be.
May 28, 2010 | Philips DVDR3330H DVD Player/HDD Recorder
Hi I haev a problem with A Philips DVDR3380/05
Use Phillips own media this unit was designed with DVD+R/RW in mind, it will work with DVD-R/RW discs but Philips invented the + format.
If you are using the DVDR 3380 is recorded video to then upload to your PC the best program is TMPGEnc v4.0 Xpress it has its own function to scan source media from a DVDR, if you use +R or + RW media you don't even have to finalise it. This is only required if you want to play a DVD-R on another standalone
I have never had any problems with SONY and PHILLIPS media, generally speaking cheap unbranded media will have a higher failure rate , but you do get what you pay for when optical media is concerned.
Hope this helps, join www.windowstipsclub.co.uk for more tips and tricks concerning DVD's
Aug 18, 2009 | Philips DVDR3380/05 DVD Recorder
Dvd player wont play movies recorded by my friends. what is the problem?
Not all DVD players can play DVDR or DVDRW discs (writable DVDs) these players are however very inexpensive. Usually the ones that say they will play windows media file will work, but not always. See if you can find one that says it will play DVDR or DVDRW discs.
Apr 13, 2009 | Bose Lifestyle 28 System
DVD+/- Gateway issue DVD won't burn DVDs but plays them
I had the same problem. I finally got a knowledgeable tech at Gateway who knew that a patch had to be downloaded. I'm sorry but I don't have the link anymore but you might be able to find it in there white papers now that you know that it exists
May 16, 2008 | Computers & Internet
LG DVD Recorder problem
is the drive a dvdr or dvdrw? if its a dvdr....rw's wont work
Nov 11, 2007 | Sony (25DPW47LS2/T) (25DPW47LS2T) 4x...
Phillips DVD Player / Recorder
Slot under front edge of player will allow you to eject by sliding lever with a small pointed object
Nov 03, 2007 | Philips DVDR 3355 DVD Recorder
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
